VisualARQ 2.8.4 is now available for download.
This is a minor release that solves most of the critical issues and crashes reported by users. Please report any problem or suggestion here or send us an email to visualarq@asuni.com.
Here is the list of changes:
Changes:
- License:
#9979: Use a secure HTTPS connection to validate license- Display:
#9957: Show tangent edges when “Tangent Edges” options is enabled in the “Display” panelFixed bugs:
- Crash:
#9980: Crash when clicking the print button while the print dialog is preparing- Grasshopper: Component:
#9844: The Update Property component doesn’t work with styles- Object: Plan View:
#9969: Scaled elements are not visible in plan views#9967: Plan View boundary control points are only visible when plan view is in the viewport- Object: Space:
#9907: Space detects walls from upper levels#9892: Space doesn’t detect insert point in the current level- Object: Stair:
#9893: Wrong stair overhead representation- Object: Wall:
#9981: I cannot extend a wall to this closed poly-surface#9964: Layer offsets are not saved when they are defined by style#9942: vaWallExtend bug#9897: Intersection lines between walls are visible when walls are inside a block- Print:
#9932: Geometry in hidden layers is printed from page layout#9139: Wrong text size when printing from layout to vector output#9105: Geometry is not printed in “Hidden” display mode
See the list of changes of VisualARQ 2.8
See the list of changes of VisualARQ 2.8.1
See the list of changes of VisualARQ 2.8.2
See the list of changes of VisualARQ 2.8.3
Enjoy!
Enric
