VisualARQ 2 - Version 2.8.2 released
VisualARQ 2.8.2 is now available for download.
This is a minor release that solves most of the critical issues and crashes reported by users. Please report any problem or suggestion here or send us an email to visualarq@asuni.com.
Here is the list of changes:
Fixed bugs:
  • Crash:
    • #9825: Crash subtracting a sphere from a wall
    • #9823: Crash when multiple threads try to access the same hatch
  • Object:
    • #9824: Blocks display wrong plan view if they are inserted at a different elevation than the original
    • #9822: VisualARQ objects changes are not correctly undone
    • #9805: Undo on an object with subtracted solid
  • Object: Plan View:
    • #9813: Hatches on wall layers missing in plan views
    • #9804: Wall join visible in plan views
  • Object: Space:
    • #9811: I can’t insert a space in an area enclosed by curves and walls
    • #9807: Space doesn’t detect insert point in the current level
  • Object: Stair:
    • #9828: Missing step in a plan view of a balanced stair
    • #9817: Wrong stair plan representation
    • #9695: Missing stairs 2D representation
  • Object: Wall:
    • #9744: Section attributes disappear after copying an object
  • Style:
    • #9816: Wrong display of plan view preview on style dialog
See the list of changes of VisualARQ 2.8
See the list of changes of VisualARQ 2.8.1
Enjoy!
Enric
Thank you. Hi Just wanted to inform you that the sliding doors have an issue so that instead of being where they are meant to be, in the centre of the wall, they are in the same position as the standard walls. For this reason, when I set them up open instead of closed, they look odd touching the wall. I didn’t see this in the list of changes, so I’m letting you know.
Hi @registration, we haven’t done any changes on sliding doors or windows. Unfortunately it is not possible yet to define the alignment of the leaves in relation to the window frame, and there is a bug when you select the Center alignment. We are pending to fix this. If you create the sliding door or window from GH you will have more control over these features. Check these multi-leaf door and window styles in food4Rhino: Sliding multi-leaf door and window | Food4Rhino
Hi @registration I let you know that in VisualARQ 3 it is already possible to change the alignment of leaves in relation to the door/window frame depth:
