VisualARQ 2.8.1 is now available for download.
This is a minor release that solves most of the critical issues and crashes reported by users. Please report any problem or suggestion here or send us an email to visualarq@asuni.com.
Here is the list of changes:
Fixed bugs:
- Attributes:
#9781: Crash when opening a document with the overhead print weight attribute changed- Crash:
#9797: Crash when dropping a file in Rhino when VisualARQ is loading Grasshopper#9794: Crash when undoing a control point change on a circle- Grasshopper: Component:
#9792: Crash when closing a document when Grasshopper has a definition in the canvas#9774: Crash baking IfcTag component- Grasshopper: Style:
#9788: Values for Plane parameters are not detected in the wizard when creating a style- Object: Column:
#7712: Error when subtracting a sphere on a column- Object: Curtain Wall:
#9777: Crash moving a curtain repeatedly- Object: Openings:
#9800: Plan cut elevation is not available for openings created with Grasshopper styles- Object: Plan View:
#9783: Furniture objects from levels below are visible in plan views#9778: Wrong plan view generation- Object: Space:
#9785: Crash dragging space objects- Object: Wall:
#9775: Wall join line visible at corners when there is an opening with overridden cut plane elevation
See the list of changes of VisualARQ 2.8
Enjoy!
Enric
