VisualARQ 2.6.1 is now available for download.
This is a minor release that solves most of the critical issues and crashes reported by users. Please report any problem or suggestion here or send us an email to visualarq@asuni.com.
Here is the list of changes:
Fixed bugs:
Block:
#8488: VisualARQ objects inside blocks are recognized as blocks after editing and
exploding the block#8382: Edit VisualARQ objects inside blocks#8363: Keep attributes and parameters of geometry after editing blocks#8622: Crash when adding an object to a blockIFC:
#9294: FC properties are not read by VisualARQ#9281: Geometry exported out of place#9269: Crash at opening IFC#9234: IFC files don’t keep the layer colorInterface:
#9291: Add Curtain Wall extend icon in the toolbarObject: Annotation:
#9296: Texts inside VisualARQ objects lose their model scale when explodedObject: Curtain Wall:
#9325: Bottom extension of a leaned curtain wall makes it change position#9319: Extension not working#9312: The top and bottom frame don’t fit to lower or upper irregular elements#9305: Very slow update of a curtain wall frame#9301: Curtain wall bottom extension errors#9311: Bottom Extension Not Working#9303: Curtain wall frame is not generated depending on components orderObject: Roof:
#9306: Gable roof gets shorter when increasing the slopeObject: Wall:
#9309: Wall Layer Top offset doesn’t work#9298: Wall layer offsets fail when wall has windowsView:
#9297: Weird edges are shown when selecting a multi-layer wall#9295: 2D curves not visible in top viewport#9280: Issues of hidden wall layers in Realistic display mode
Enjoy!
Enric
