Is there a way to rearrange the viewport tabs at the bottom of the UI? The tabs that sit just under the viewports?
Thank you,
Sach
Hi Sach -
No. The feature request is on the list as RH-2183 [Drag - Drop Tab Rearrangement]. I’ve added this thread.
Thanks Wim
I hope this can be built in soon. I often want to exercise as much control as possible over any UI environment to minimize flurries of little decisions while focusing on larger issues. This may sound crazy, but having tabs out of any logical order is like someone misplacing your reference drawings (that someone is ME unfortunately, but still…) Thanks! Keep up the great work. Rhino is such a wonderful tool; may it remain relevant, snappy and tight.
You can shuffle the order of layout tabs using the Layouts panel - just drag and drop to re-order.
– Dale
It’s also frustrating that the tabs change order after document saved and reopened.
Whichever tab was active during save will be first after reopening the document.
oh, I thought I was imagining that. It’s pretty frustrating/ I just want to be able to position the tabs where I like!
Hi Vano -
I haven’t been able to reproduce that here. Could you please post your SystemInfo data and steps that I can follow to make this happen?
My tabs also rearranged again yesterday.
I thought that I might have mistakenly assigned a new ‘set view’ elevation to those viewports, but I’m pretty sure I didn’t.
Sure.
- Open a drawing (or create a new one)
- Switch viewport to most right tab (I think by default it’s
Rightviewport) and make it full window - Save drawing
- Re-open the drawing again
- the
Righttab is now most left tab
I can reproduce this in Rhino8 as well as in Rhino9
System info
Rhino 8 SR35 2026-9-8 (Rhino 8, 8.35.26251.13001, Git hash:master @ 3645d710f50175d8ebcf404aded5b042a481c23e)
License type: Commercial, build 2026-09-08
License details: Cloud Zoo
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 16GB)
.NET 8.0.31
Primary display and OpenGL: NVIDIA GeForce RTX 2060 (NVidia) Memory: 6GB, Driver date: 3-4-2026 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 595.79
- Windows Main Display is laptop's integrated screen or built-in port
Primary OpenGL: NVIDIA GeForce RTX 2060 (NVidia) Memory: 6GB, Driver date: 3-4-2026 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 595.79
Secondary graphics devices.
Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 6-1-2021 (M-D-Y).
- There are no monitors attached to this device. Laptop lid is probably closed
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Graphics level being used: OpenGL 4.6 (primary GPU's maximum)
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 3-4-2026
Driver Version: 32.0.15.9579
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp "Commands" 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\rdk.rhp "Renderer Development Kit"
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp "Rhino Render" 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp "RDK_EtoUI" 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\NamedSnapshots.rhp "Snapshots"
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp "MeshCommands" 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\SectionTools.rhp "SectionTools"
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp "RhinoCycles" 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp "Toolbars" 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\3dxrhino.rhp "3Dconnexion 3D Mouse"
C:\Program Files\Rhino 8\Plug-ins\Displacement.rhp "Displacement"
Hi Vano -
Thanks → RH-99390 Viewport Tabs: Don’t Automatically Change Order
Thanks Dale, for some reason this doesn’t work for me – but I think it used to; just as you describe. Is there a setting somewhere that would lock these, that I may have checked by mistake?
Hi Christopher -
Please run the Rhino SystemInfo command and copy-paste its output here.
RH-99390 is fixed in Rhino 9 Service Release 2 Release Candidate
