I have been down the rabbit hole trying to figure out this issue. I’ve uninstalled and reinstalled both rhino and my nvidia drivers and attempted to adjust other system setting.
Here is my info
Rhino 7 SR38 2024-12-3 (Rhino 7, 7.38.24338.17001, Git hash:master @ 97e36efa02d7f71638988290bb2d190fcf1b18c5)
License type: Educational, build 2024-12-03
License details: Cloud Zoo
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 32Gb)
Computer platform: LAPTOP - Plugged in \[100% battery remaining\]
Primary display: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 128MB, Driver date: 2-21-2024 (M-D-Y).
* Windows Main Display is laptop’s integrated screen or built-in port
* Secondary monitor attached to adapter port #1
Primary OpenGL: NVIDIA GeForce RTX 3070 Ti Laptop GPU (NVidia) Memory: 8GB, Driver date: 6-23-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 516.59
* Video pass-through to primary display device
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-23-2022
Driver Version: 31.0.15.1659
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\\Program Files\\Rhino 7\\Plug-ins\\Commands.rhp “Commands” 7.38.24338.17001
C:\\Program Files\\Rhino 7\\Plug-ins\\rdk.rhp “Renderer Development Kit”
C:\\Program Files\\Rhino 7\\Plug-ins\\RhinoRenderCycles.rhp “Rhino Render” 7.38.24338.17001
C:\\Program Files\\Rhino 7\\Plug-ins\\rdk_etoui.rhp “RDK_EtoUI” 7.38.24338.17001
C:\\Program Files\\Rhino 7\\Plug-ins\\rdk_ui.rhp “Renderer Development Kit UI”
C:\\Program Files\\Rhino 7\\Plug-ins\\NamedSnapshots.rhp “Snapshots”
C:\\Program Files\\Rhino 7\\Plug-ins\\RhinoCycles.rhp “RhinoCycles” 7.38.24338.17001
C:\\Program Files\\Rhino 7\\Plug-ins\\Toolbars\\Toolbars.rhp “Toolbars” 7.38.24338.17001
C:\\Program Files\\Rhino 7\\Plug-ins\\3dxrhino.rhp “3Dconnexion 3D Mouse”
C:\\Program Files\\Rhino 7\\Plug-ins\\Displacement.rhp “Displacement”
Primary OpenGL: NVIDIA GeForce RTX 3070 Ti Laptop GPU (NVidia) Memory: 8GB, Driver date: 10-9-2025 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 581.57
Integrated accelerated graphics device with 4 adapter port(s)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 10-9-2025
Driver Version: 32.0.15.8157
when you updated your driver, did you use clean install or just the basic?
if you did not use the custom/advanced install with the clean install check box, do it again, but do it clean install. Otherwise you are just patching over what may be a bad driver.
also did you use the game ready driver or the studio… if it’s still misbehaving after a clean install and restart, try the other driver. Some machines work great with game, some with studio and I have not been able to tell why one works better than the other for some machines.
still having trouble? call us 206-545-6877 8-5 pst (closed 12-1 for lunch)
I have finally been able to comeback to this issue and have tried the fix’s explained and several others. Rhino7 is continuing to freeze anytime I attempt to use the make 2d option or the text option in layouts. I will call
