Rhino 6 freezing
Whenever I use Rhino 6 now it keeps freezing. This happens especially when I am trying to drag something or bring in a picture. I have had a problem with this in v6 for a while, but sometimes it is better and sometimes it is worse. Before it would freeze my whole computer up and I would have to reboot. Now it just freezes rhino, then the screen goes momentarily black, and then Rhino is just stuck in “not responding” until I restart it. As you can imagine, this is quite annoying as I sometimes lose work, and lose a lot of time. Here are my system specs if anyone can help me understand what is wrong.
Rhino 6 SR8 2018-8-28 (Rhino 6, 6.8.18240.20051, Git hash:master @ d037927543424e8b3ce54e46b435866178a6349c)
Licence type: Educational, build 2018-08-28
License details: Cloud Zoo. In use by: Robin Harrison ()
Windows 7 SP1 (Physical RAM: 7.9Gb)
Machine name: L27501
AMD FirePro M6000 Mobility Pro Graphics (OpenGL ver:4.5.14565 Compatibility Profile Context FireGL 24.20.12024.10)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.5
Shading Language: 4.50
Driver Date: 7-17-2018
Driver Version: 24.20.12024.10
Z-Buffer depth: 24 bits
Total Video Memory: 2 GB
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.8.18240.20051
C:\Program Files\Common Files\McNeel\Rhinoceros\6.0\Plug-ins\ProRender (2aae3eb3-985b-4e64-b19a-fed69ef9dfeb)\2018.1.18.804\ProRender\ProRender.rhp “ProRender”
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.8.18240.20051
C:\Users\robinharrison\AppData\Roaming\McNeel\Rhinoceros\6.0\Plug-ins\PanelingTools (6caed836-bc06-4ebc-b1fd-e10886a0dc94)\2017.11.17.800\PanelingTools.rhp “PanelingTools”
C:\Program Files\Rhino 6\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.8.18240.20051
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.8.18240.20051
I would also like to report this issue, rhino keeps freezing in the same way as Robin mentioned.
When i set the anti aliasing to 2x, the freezes are gone. (horrible drawings, but Rhino runs much better :slight_smile:
Maybe that is something to try @robinharrison ?
Excuse my ignorance. Doesn’t anti-aliasing just mean render quality? I’m not sure how that would effect Rhino when I am not rendering.
No. AA has to do with the how hard the display driver and adapter work to try to smooth out the appearance of diagonal curves and edges in the on-screen display.
Yes, there are AA controls for rendering too, but this is for working display, not for rendering.
It’s also possible you are running a hybrid computer that also has an embedded Intel display adapter.
A recent Windows 10 (1803 edition) seems to have caused a problem on these systems. The fix is to download and install the Intel driver from September 2018.
Use the Windows Device Manager to check the Date of the drivers if you have an Intel GPU in addition to your AMD.
you are win 7sp1-
min req is sp2- pls update to at least win 7 sp2 to run v6.
There is no “real” SP2… totally unofficial designation.
good to know- thanks
I set anti aliasing to 2x and tried to make a rectangle to see how it looked and rhino froze again.
2018-11-08%2012_34_40-AMD%20FirePro%20M6000%20Mobility%20Pro%20Graphics%20Properties
Here are my driver specs
Does the hybrid computer issue apply to Windows 7?
I believe so, but I’m not positive. It seems the worst problems are with Windows 10 (1803).
Generally speaking, having updated display drivers are better than old ones. It’s very rare when a new driver causes problems, but it can happen.
Still having this problem. Is someone able to help me understand what is wrong? I would very much like to be able to use Rhino 6. I reinstalled it just in case that would help and it didn’t.
You have not verified that you have met the min OS requirements which is the latest service pack of win 7.
please run windows update and install all “important” or “critical” updates and try rhino again.
This might be helpful for getting Windows 7 fully updated:
Ok. Makes sense now. Will look into that.
Although I have updated to windows 10 a while ago, I am still getting this same problem as before. My graphics driver is up to date, and anti-aliasing is at 2x. It’s sort of a pain to not be able to use it, and I have to use some plugins that don’t work on V5 for class.
Hi Robin, could you please run the SystemInfo command again and post the result here?
Thanks,
Rhino 6 SR17 2019-8-23 (Rhino 6, 6.17.19235.15041, Git hash:master @ 06b69c5cc21d880aa793a5a7cfd454a66f6213bb)
License type: Educational, build 2019-08-23
Windows 10.0 SR0.0 or greater (Physical RAM: 7.9Gb)
Non-hybrid graphics.
Primary display and OpenGL: AMD Radeon HD 7800M Series (AMD) Memory: 2GB, Driver date: 8-23-2019 (M-D-Y). OpenGL Ver: 4.6.13571 Compatibility Profile Context FireGL 19.8.2 26.20.13001.40003
OpenGL Settings
Safe mode: Off
Anti-alias mode: 2x
Render version: 4.6
Shading Language: 4.60
Driver Date: 8-23-2019
Driver Version: 26.20.13001.40003
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.17.19235.15041
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.17.19235.15041
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.17.19235.15041
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.17.19235.15041
Hi Robin, thanks for that info.
Which plug-ins specifically? I don’t see any out of the ordinary plug-ins in the list.
Does the problem also appear when you run Rhino in safe mode?
Can you describe your peripherals - number and connection to external monitors?
