Trying to export some views from the model. I have managed to export a few but some views just keep crashing. I tried to update the drivers but no help.
This is the scene. Cant post file since its contest proposal.
didnt help. my nerves are done. month of work in jepardy because i cant make exports. i know it doesnot need to be rhinos fault in this world full of faulty drivers (nvidia)…
Well, your video card only has 2Gb of memory, so it is possible a very large image might exceed its capacity - I don’t know how Rhino works in this case. If the same image at a smaller pixel size does not crash, then that might be the problem.
You’re also on Windows 7, that is no longer ‘officially’ supported, but hopefully that is not part of the problem.
i dont think it may exceed 2gb its maybe 3000x3000pixels picture. ok lets find solution. is there a way i can jus render a pic and get the same result like in render mode in viewport? thing is i have never used rhino render and have no time to study it…
i need this picture which is displayed in rendered mode to save in high res. i tried and failed viewcapturetofile. now i need to render it so that it looks like in viewport.
I think it is very likely that the 2GB of VRAM is the problem here, like @Helvetosaur suggested. Try with lower resolutions first and see if that works.
now I have a question. wouldn’t it also depend on the size of the model if the VRAM is sufficient or not? if that is the case, then maybe you can reduce the complexity of your geometry/mesh in order to reduce the filesize and avoid potential VRAM issues.
i will have to look into that but please is there a way rhino can render real time like displayed in vieport? it take no time to orbit my model in rendered mode i just need to render the same thing in high res which would take maybe 4x more --> still no time
Don’t know what you can do. Have you tried lower resolutions? Does it crash as well with lower resolution? If raytraced takes too long, you can also adapt the other display modes in the settings, so they fit you desired style a bit more. Do the other display modes also crash when you use ViewCaptureToFile?
Hello @all, I am experiencing the same problem as @ivan.galik when I try to ViewCaptureToFile a Perspective view using the ‘Arctic’ display mode. Just have updated my Graphics Driver, which was admittedly very old before, but that didn’t do the trick. The resolution that I am aiming for is not at all that high (maybe approx. 2500px longer side), is there another fix for this currently?
I could repeat the crash every time, and the GPU fan turns on real loud before rhino shuts down. So I am sure it is a GPU problem, Raytracing works fine however (Cycles is CPU based, or GPU based?)
