I’ll try to gather everything in one place instead…
SCROLLBAR STYLING
ICON SCALING
Not all icons get scaled it seems.
However, those
cogwheels apparently do scale (but only after a restart)… ![]()
EDIT: The above panel had large and small icons, whereas the below panel has large and large icons. There’s no consistency here (and seemingly no design intent or uniform theme for the icons).
TEXT SCALING
Seems you can only scale the command line text, yet I see at least three different text sizes in the UI.
COLOR STYLING
There’s very limited UI color styling options, for example I can’t change the 100% solid black backgrounds of text boxes as seen in the screenshot above and you can’t change the highlight color of the options along the bottom of the window.
This separator in the main toolbar seems to use a text color, when it probably should use the general frame background color (also, no styling option for adding breathing room as I’ll mention below).
EDIT: When a named panel background has nothing in it, it’s the content background color (which is fine), but when it’s populated it suddenly has an entirely different non styled color (and both cases has a 1 pixel outline which other panels lack).
Oh, and the third odd one out is the Named Selections which does have a black empty list before anything has been added and no 1 pixel outline (and almost no tools in its poor toolbar either)… ![]()
Aaaaand the Materials panel is a fourth styling with two different highlight colors and a weird horisontal seamless realtime zoom… do we really need that here in an UI which otherwise feels already quite aged? Do people seamlessly zoom materials often or doesn’t the thumbnails context menu suffice and we could instead reduce visual clutter?
(Plus, design theme intent nitpick… the UI has seemingly been flattened, yet those icons in the bottom right corner have a beveled look… almost Windows 3.1/95 styled.)
LAYOUT STYLING
There’s no way to style the breathing room between UI elements, and things like the active tab on the top toolbar melt together with the menu bar above, while active tabs on panel windows have a 1px breathing room.
Meanwhile, the tabs along the bottom of the screen have a 1 pixel outline in their active and hovered states.
Also there’s a 2 pixel gap between docked panels, but in this bottom left corner there seems to be 0 (same for the top of the screen, actually).
