Please get rid of the useless “Save changes… ?” warning when it’s obviously useless.
This happens frequently when one opens Rhino and is distracted while the initial popup appears.
Then the default template will load, and if you don’t want to start something from scratch, then you’ll try to open a file, and Kaboom : this silly warning appears.
The rule could be : if the only command in the command line is “Open”, then don’t pop-up the warning because there is actually nothing to save !
I agree that after firing up Rhino. When you hit Open to open an existing file it’s rather silly that Rhino asks if you want to save the current file. Because the file is just an untouched template.
IIRC In the past this was also implemented for files that were opened and only some view changes were done.
@John_Brock why would an untouched new file would need saving?
I suspect something else is going on here.
When I start Rhino using a template file and then immediately click New, I am not getting a message to Save.
By chance are you configured to automatically run commands when Rhino starts in Options > General?
The way the system is designed to work is if anything like geometry or adding a Layer to a file happens, then you are asked if you want to save those changes.
If nothing is added or removed to/from the file, then you’re not asked.
Zooming or Rotating a display falls in this list of ignored changes.
it happens here also all the time. I have V-Ray installed. Better contact Chaosgroup about this, they said they could fix it for me by logging in on my system. But I wasn’t ready for that
I’m assuming that could also be virtual stuff like document/user text or user data - stuff that might be invisible “to the naked eye”… In any case my V-Ray doesn’t seem to do this, but there might be scenes loading with materials or something else that I don’t have.
