All of a sudden I have this problem with Rhino not remembering the toolbar window positions. I googled and found a topic discussing this for Rhino 5 and looked at the registry and saw that in Rhino 6 and 7 there is no entry for Window Positions? Is that normal?
I tried to repair Rhino 6 and also uninstalled and reinstalled and it’s still the same.
What can I do to avoid having to move around toolbars every time I open Rhino?
Hello - I’d try loading EvoluteTools from a different location first and see what happens - the EvoluteTools one will reset because it is in Program Files and that is not a location that can be written by Rhino. If you make a copy elsewhere and load that instead, it should behave - it could be that this is messing the layout of your other rui as a side effect.
oh this is funny, moved all toolbars on just the laptop screen with the external screens switched off. Then opened Rhino 6 as admin and the toolbars are where they should be. Same if I open Rhino 6 from the taskbar.
