Toolbar layout not saved
I keep the selection filter at a place, but whenever I reopen Rhino, the it is at a different place. Is there a way I can save the layout of toolbars?
rhino 6, 7,8?
Rhino 7!
screen shots of before and after? do you have it docked to a location or simply floating in space?
This is the layout that I get whenever I reopen Rhino or start a new project.
This is the layout I want to save as default. I want the Selection Filter to be with the cammand bar.
hi @ferhyunt can you send your systeminfo?
I cannot repeat your issue here. The settings are stored here
%appdata%\McNeel\Rhinoceros\7.0\settings
What happens if you delete the xml files, then restart Rhino, make you changes, Close Rhino and then reopen?
