SetDotNetRuntime Error
Hello everyone,
I have recently updated to Rhino 8 and installed the new ShapeDiver plugin. During installation, I have received the following error,
"Loading the SdRhinoStargateClient plugin is not supported yet if Rhino 8 is using .NET 7. To fix this, please use the “SetDotNetRuntime” command of Rhino 8 and switch to .NET Framework.
I did exactly that, and switched from Default (which is I assume the NETCore) to NETFramework, and the ShapeDiver plug-in started working. However, now I have other plug-ins that are not running properly. (DraftHorse for example).
Will there be a solution to this compatibility issues or we have to switch the NET Runtime settings everytime and restart Rhino?
This is currently not possible in Rhino 8 but we will update the plugin as soon as it is. I will update this topic once the situation is resolved.
Thanks Mathieu.
Do you know when this update will be released?
@Hugo_Chinaglia we are almost there. There is a final problem blocking us from releasing this, should be fixed in Rhino 8 SR 7. Related links:
https://mcneel.myjetbrains.com/youtrack/issue/RH-80648/Yak.exe-fails-with-multi-targeted-plugin
Hi Folks,
I’m having some trouble with the SdRhinoStargateClient today - I’ve tried changing to .NET Framework, but it was still throwing up errors. I’ve tried reinstalling ShapeDiver and updating graphics drivers/OS. However it seems to continue having a problem - attaching SysInfo below
Rhino 8 SR23 2025-9-8 (Rhino 8, 8.23.25251.13001, Git hash:master @ e75a9d62e23cc6f52d4ef68eb7eda9f8da9b6cd9)
License type: Educational, build 2025-09-08
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 64GB)
.NET 8.0.17
Computer platform: LAPTOP  - Plugged in [100% battery remaining]
  Primary display: Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 8-13-2024 (M-D-Y).
        - Windows Main Display is laptop's integrated screen or built-in port
  Primary OpenGL: NVIDIA GeForce GTX 1650 (NVidia) Memory: 4GB, Driver date: 9-22-2025 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 581.42
    > Integrated accelerated graphics device (shares primary device ports)
OpenGL Settings
  Safe mode: Off
  GPU Tessellation is: On
  Graphics level being used: OpenGL 4.6 (primary GPU's maximum)
  Anti-alias mode: 4x
  Mip Map Filtering: Linear
  Render version: 4.6
  Shading Language: 4.60 NVIDIA
  Driver Date: 9-22-2025
  Driver Version: 32.0.15.8142
  Z-Buffer depth: 24 bits
  Total Video Memory: 4 GB
  C:\Program Files\Rhino 8\Plug-ins\Commands.rhp	"Commands"	8.23.25251.13001
  C:\Program Files\Rhino 8\Plug-ins\rdk.rhp	"Renderer Development Kit"
  C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp	"Rhino Render"	8.23.25251.13001
  C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp	"RDK_EtoUI"	8.23.25251.13001
  C:\Users\Onufr\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\PanelingTools\2024.8.20.677\PanelingTools.rhp	"PanelingTools"
  C:\Program Files\Rhino 8\Plug-ins\NamedSnapshots.rhp	"Snapshots"
  C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp	"MeshCommands"	8.23.25251.13001
  C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp	"RhinoCycles"	8.23.25251.13001
  C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp	"Toolbars"	8.23.25251.13001
  C:\Program Files\Rhino 8\Plug-ins\3dxrhino.rhp	"3Dconnexion 3D Mouse"
  C:\Program Files\Rhino 8\Plug-ins\Displacement.rhp	"Displacement"
  C:\Program Files\Rhino 8\Plug-ins\SectionTools.rhp	"SectionTools"
Please share the output of clicking on „Details“.
There isn’t one - it just opens https://www.rhino3d.com/docs/guides/netcore/
When opening Grasshopper, I get these though:
Ok many thanks for checking. Please have a look at this and give it a try: Issues downloading from package manager - #2 by mathieu1
Thank you very much - uninstalling and deleting the ShapeDiver folder from \Roaming\McNeel\Rhinoceros\packages\8.0 seems to have helped when reinstalling
