ShapeDiver GH Plugin fails when SetDotNetRuntime set NETCore
The ShapeDiver Grasshopper Plugin doesn not start up properly when Rhino Command “SetDotNetRuntime” is set to “NETCore”, which is however the default state for latest Rh releases and some other plugins do require this setting.
Rhino Version 8 SR25
(8.25.25302.9531, 2025-10-29)
ShapeDiver 1.29.1
@ ShapeDiver developer team: Please fix this bug.
Please report the error you are getting when loading the ShapeDiver plugin, so our team can help you with this issue.
Please see this: ShapeDiver Component "3dm Export Options" won't accept V8 - #3 by snabela
I also tested using the latest service release candidate Rhino 8 SR 25, and it works as expected. Please review your folder `%APPDATA%`\McNeel\Rhinoceros\package` for unused versions of the ShapeDiver plugin and remove them if you find some.
I am using
Rhino 8 SR 25
Please try what I explained above.
I did what you suggested, and there were no packages I could find.
So I deinstalled ShapeDiver and re-installed it and now it works again.
