Rhino WIP Feature: New Default Hatch Patterns
Rhino WIP ships with 58 new hatch patterns.
Why This Feature?
Previous versions of Rhino shipped with only 9 basic hatch patterns (Solid, ANSI31, ANSI32, etc.), which covered fundamental drafting needs but left users needing to create or import custom patterns for more specialized applications like:
  • Architectural materials: Representing concrete, stone, or other finishes in sections and elevations
  • Landscape elements: Showing ground textures, plantings, or hardscape materials
  • Construction details: Distinguishing between different material types in technical drawings
While users could always import .pat files or create custom patterns, having a comprehensive library included by default streamlines the workflow and provides professional-quality patterns ready to use. These 58 patterns cover common architectural, landscape, and engineering representation needs without requiring additional downloads or pattern creation.
New hatches include complex patterns such as:
  • Concrete
  • Rattan
  • Rubble
  • Stone
How to Access the New Patterns
New template files will automatically include access to all 58 default patterns.
  1. Open the Hatch Pattern panel (Options > Document Properties > Hatch)
  2. Click the + (Show Image) to load patterns
  3. All 58 patterns will now be available in your pattern list
The patterns are stored in: %appdata%\McNeel\Rhinoceros\9.0\Localization\en-US\Hatch Patterns
This is all part of a general update to hatches in the Rhino WIP.
Related updates to hatches:
I like all of them the only ones i am missing is irregular wood grain:
Some like these:
Normal Wood, Fine Wood, Rough wood
@mi.land
You can make them by yourself with the new HatchPattern command in Rhino WIP.
I already have wood pattern in v8 and nice that it is possible to make them, i asked more as a wish of default wood pattern. More for beginner and students, if you work on the default stuff anyway.
Here is a sample of created pattern thru Grasshopper using this method: * Creating New Hatch patterns with Grasshopper in Rhino 9
Wood smooth
Wood smooth.3dm (1.1 MB)
wood smooth.gh (14.1 KB)
Nice would be perfect to be added to the default ones, carpenter and rhino teacher talking here :wink:
creating your own pattern inside rhino is a dream, no more 3rd party appsšŸ™‚
60 is anyway a more complete number than 58
Hi Scott
In wip 9, I don’t seem to have any hatches other than solid??
the image below is what is see in options:
am I doing something wrong?
A
Hi Adrian -
Traditionally, the default template files did not contain any hatch patterns. When a user added an hatch, Rhino would automatically populate the collection with the 9 default patterns.
Currently, when opening an existing file, Rhino will look for that ā€œSolidā€ pattern. When that exists, Rhino assumes that the user has the pattern they need and will not do anything more.
In that case, you can add the new default patterns by using the blue circular arrow icon:
We’re not convinced that automatically adding all new default hatch patterns in any file is the best way forward here. Perhaps a user should be able to see the patterns that are available somehow and selected those that are needed for the project?
Feedback on all aspects of this new feature is welcomed.
Do you have Grasshopper currently running on that file? ARe there any startup plugins running?
I might try and open Rhino 9 WIP fresh, no Grasshopper and see if the hatches populate?
Also, version information in the Systeminfo would help.
We have been messing with the way the new hatches load in the last couple builds. The folder that the hatches exist in is:
Hi Scott
Thankyou for your reply info below:
  • Grass hopper not running
  • Plugins running😐
  • System info version
See if an update works better. I see that one is a fewer days old. I think there was one from yesterday?
Hi Scott
I seem to be midding the folder you listed below, this is what I have:
Hi Adrian -
That’s not the correct folder. You are in AppData -> Local; Scott’s path opens AppData -> Roaming.
At any rate, are you saying that using the button I mentioned doesn’t do anything?
Nope. Apparently, that’s pending some work on the Splash Screen…
Hi Wim
Sorry, I didn’t see your post as I was working from the email that came through and didn’t follow through to the actual post….
Now I have read it and I tried the blue button and it works, thankyou.
Personally I think that hatches should be visible / selectable, I often chose a simple lined one in rhino 8 and then played with scale and angle to get what I wanted, but I also used various others for detailing.
the blue button option was not obvious, and as I expected to see some hatches I thought it was an error…
A
You shouldnt have to dig around in any folder to load the new patterns into existing files.
For the moment, clicking the 0028 to reload defaults is all you need. If that’s not working then there’s a bug. The new patterns either aren’t in the installer, or some other bug is happening.
The UI for this area of the program is in the middle of a complete rewrite so expect some flux here as we figure out the way forward. Its most likely going to end up as something similar to the way materials are managed. What we figured out that we don’t want is to add 50+ hatch patterns to every 3dm file you make and that’s currently what previous versions of Rhino did with the 9 older patterns.
