Hi, I’m using a new laptop with hybrid graphics.
The rhino 7 doesn’t pick NVDIA as the primary display
i have tried the solutioin of
However, it doesn’t work, my OpenGL still appears as intel display.
Any helps will be greatly appreciated!
What’s the laptop? What’s the complete information in systeminfo in Rhino?
It looks like there’s no driver installed at all for the integrated Intel video. That doesn’t seem right even if you’re trying to not use it.
It’s Razer Blade 15, it is a company’s laptop.
Really dont know how to deal with this…
Here is the full systeminfo.
Thanks a lot!
Rhino 7 SR11 2021-10-20 (Rhino 7, 7.11.21293.09001, Git hash:master @ 972ac562128b307e99f15e56dd11586c73e91ecb)
License type: Commercial, build 2021-10-20
License details: Cloud Zoo
Windows 10.0.19042 SR0.0 or greater (Physical RAM: 32Gb)
Computer platform: LAPTOP - Plugged in [60% battery remaining]
Primary display and OpenGL: Microsoft Basic Display Adapter (Intel) Memory: 0MB, Driver date: 6-21-2006 (M-D-Y). OpenGL Ver: 1.1.0
> Integrated graphics device with 1 adapter port(s)
Secondary graphics devices.
NVIDIA GeForce RTX 3070 Laptop GPU (NVidia) Memory: 8GB, Driver date: 10-13-2021 (M-D-Y).
- This device is not being used
ATTENTION:
No graphics device is being used. Either an error occurred on startup, or certain devices have been disabled.
See below for any possible configuration changes that may help resolve this issue.
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 2.1
Anti-alias mode: None
Mip Map Filtering: Linear
Vendor Name: Microsoft Corporation
Render version: 0.0
Shading Language: Not supported
Driver Date: NA
Driver Version: NA
Maximum Texture size: 1024 x 1024
Z-Buffer depth: 32 bits
Total Video Memory: 64 MB
C:\Users\kwu\AppData\Local\Programs\Enscape\Bin64\Enscape.Rhino7.Plugin.dll “Enscape.Rhino7.Plugin” 0.0.21250.810
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.11.21293.9001
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.11.21293.9001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.11.21293.9001
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.11.21293.9001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.11.21293.9001
See if this helps:
Hi John.
Thanks for your reply.
I have tried this solution but it doesn’t work for me…
Well IT is going to have to look at it if that stuff is locked down…'cause it says right there that there is no device being used, there’s no driver for the Intel graphics and nothing is working.
Hi Jim,
I have checked the device manager
it appears normal
is it a rhino problem that it actually blocked the graphics…
No, a “Microsoft Basic Display Adapter” is a big problem. There’s no driver for the Intel graphics.
Hi -
That’s not how it works. Hardware resources are completely managed by the Windows OS and Rhino is only on the receiving end.
That does not appear normal.
The first display adapter that is listed is a “Microsoft Basic Display Adapter”. That should be some Intel of some kind. That looks like the result of uninstalling the drivers for that GPU and then not installing new ones.
Please make sure that you have rebooted the machine and read the following post - then try what Jeff suggested about finding the drivers for that device.
Thanks a lot Wim!
The problem already fixed.
