We are having an issue where rhino does not use the high performance graphics card, regardless of settings. It is similar to what has been described here and here. This issue happens in Rhino 7 & Rhino 8, for laptop users that are not connected to an external display. The built-in intel graphics card is always used, regardless of settings.
We have tried:
Settings>system>display>Graphics>Rhino>high performance (Nvidia)
Device Manager>Display Adapters>Disable Intel Graphics Card
Nvidia Control Panel>Manage 3D settings>Preferred Graphics Processer>Nvidia…
and
Program settings>Select program to customize>Rhino (file path: C:\Program Files\Rhino 8\System)>Add>Select graphics processor to use for this program> Nvidia
After all that, _SystemInfo still says: (Nvidia not being used)
Rhino 8 SR5 2024-3-12 (Rhino 8, 8.5.24072.13001, Git hash:master @ e3530849b75f00b2b977766a567ae29b055837e9)
License type: Commercial, build 2024-03-12
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 40GB)
.NET 7.0.18
Computer platform: LAPTOP - Plugged in [62% battery remaining]
Secondary graphics devices.
NVIDIA GeForce RTX 3070 Laptop GPU (NVidia) Memory: 8GB, Driver date: 3-1-2024 (M-D-Y).
- This device is not being used
Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 12-12-2022 (M-D-Y).
> Integrated graphics device with 0 adapter port(s)
- There are no monitors attached to this device. Laptop lid is probably closed
ATTENTION:
No graphics device is being used. Either an error occurred on startup, or certain devices have been disabled.
See below for any possible configuration changes that may help resolve this issue.
- Any hardware configuration or cabling changes you make will require that you restart Rhino.
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 0.0 (primary GPU’s maximum)
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Microsoft Corporation
Render version: 0.0
Shading Language: Not supported
Driver Date: 12-12-2022
Driver Version: 31.0.101.3962
Maximum Texture size: 1024 x 1024
Z-Buffer depth: 32 bits
Total Video Memory: 1 GB
C:\Program Files\Enscape\Bin64\Enscape.Rhino8.Plugin.dll “Enscape.Rhino8.Plugin” 0.0.23328.1419
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.5.24072.13001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.5.24072.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.5.24072.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.5.24072.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.5.24072.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.5.24072.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.5.24072.13001
Any help would be much appreicated!
-Andy
