Rhino 7 + 8 appear to not be using my Nvidia GPU.
I only noticed this after a debilitating slow down in my viewports and not being able to print PDFs.
How do I fix this? Urgent issue! Any rapid responses would be most appreciated!!!
SystemInfo below says the Nvidia card is not being used…
Rhino 8 SR9 2024-7-8 (Rhino 8, 8.9.24190.17001, Git hash:master @ c9e437cfdf6e9fc57bba3cd084318a04f8b7e355)
License type: Commercial, build 2024-07-08
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.0
Primary display and OpenGL: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 1GB, Driver date: 12-9-2023 (M-D-Y). OpenGL Ver: 1.1.0
- Secondary monitor attached to adapter port 1
- Windows Main Display attached to adapter port #2
Primary OpenGL: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 1GB, Driver date: 12-9-2023 (M-D-Y). OpenGL Ver: 1.1.0
> Integrated (slow!) graphics device with 4 adapter port(s)
Secondary graphics devices.
NVIDIA RTX A3000 12GB Laptop GPU (NVidia) Memory: 12GB, Driver date: 5-23-2024 (M-D-Y).
- This device is not being used
ATTENTION:
Laptop is using the slower, less reliable integrated graphics device and probably needs a configuration change.
- Any hardware configuration or cabling changes you make will require that you restart Rhino.
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 0.0 (primary GPU’s maximum)
Anti-alias mode: None
Mip Map Filtering: Linear
Vendor Name: Microsoft Corporation
Render version: 0.0
Shading Language: Not supported
Driver Date: NA
Driver Version: NA
Maximum Texture size: 1024 x 1024
Z-Buffer depth: 32 bits
Total Video Memory: 64 MB
C:\Program Files\Bongo 2.0 (64-bit)\Rhino6\Bongo.20.rhp “Bongo 2.0”
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Bongo 2.0 (64-bit)\BongoUI.20.v60.rhp “BongoUI20v60”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.9.24190.17001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.9.24190.17001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.9.24190.17001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.9.24190.17001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.9.24190.17001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.9.24190.17001
C:\Program Files\Rhino 8\Plug-ins\Calc.rhp “Calc”
