For context I recently swapped my laptops LCD display because I damaged the original. It is a hybrid laptop that should be running both an Intel and Nvidia video card drivers. I found that the new screen only works if I disable the Intel driver under display adapters in the device manager. This has not affected any other apps that I am aware of, but Rhino 8 is having problems. Line types no longer display properly, anything in 3D view is far slower than before and rhino will crash if I try to render anything. System info tells me that The graphics card is recognized as a secondary device but also says “ATTENTION No graphics device is being used.”
Interestingly if I enable the Intel display adapter and plug my laptop into a monitor it works completely fine, however my laptop screen goes black.
I understand that this may be a deeper software issue not just related to rhino but please let me know if anyone has any solutions.
Here is my systeminfo: (intel display adapter disabled):
Rhino 8 SR14 2024-12-10 (Rhino 8, 8.14.24345.15001, Git hash:master @ cdb74b46090a23fe242c51b288886f76467a741b)
License type: Educational, build 2024-12-10
License details: Stand-Alone
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 16GB)
.NET 7.0.0
Computer platform: LAPTOP - Unplugged [35% battery remaining] ~35 minutes left
Secondary graphics devices.
NVIDIA GeForce RTX 4060 Laptop GPU (NVidia) Memory: 8GB, Driver date: 6-25-2024 (M-D-Y).
- This device is not being used
Intel(R) Arc™ Graphics (Intel) Memory: 2GB, Driver date: 9-13-2024 (M-D-Y).
> Integrated graphics device with 0 adapter port(s)
- There are no monitors attached to this device. Laptop lid is probably closed
ATTENTION:
No graphics device is being used. Either an error occurred on startup, or certain devices have been disabled.
See below for any possible configuration changes that may help resolve this issue.
- Any hardware configuration or cabling changes you make will require that you restart Rhino.
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Graphics level being used: OpenGL 0.0 (primary GPU’s maximum)
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Microsoft Corporation
Render version: 0.0
Shading Language: Not supported
Driver Date: 6-25-2024
Driver Version: 32.0.15.5612
Maximum Texture size: 1024 x 1024
Z-Buffer depth: 32 bits
Total Video Memory: 8188 MB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.14.24345.15001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.14.24345.15001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.14.24345.15001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.14.24345.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.14.24345.15001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.14.24345.15001
Here is the systeminfo (Intel display adapter enabled plugged into external monitor):
.NET 7.0.0
Computer platform: LAPTOP - Unplugged [88% battery remaining] ~133 minutes left
Primary display and OpenGL: NVIDIA GeForce RTX 4060 Laptop GPU (NVidia) Memory: 8GB, Driver date: 6-25-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 556.12
Primary OpenGL: NVIDIA GeForce RTX 4060 Laptop GPU (NVidia) Memory: 8GB, Driver date: 6-25-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 556.12
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Shading Language: 4.60 NVIDIA
Z-Buffer depth: 24 bits
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
