brian
(Brian Gillespie)
61
Rhino 9 WIP (9.0.25259) is now available for Windows and Mac
Bugs Fixed:
- Annotation: Hatch:
- Ctrl(CMD)+click does not deselect patterns (RH-87593)
- Import overwrite is reverted in RhinoWIP (RH-89136)
- Camera: Cannot select camera points (RH-89465)
- Clipboard: Repeating PasteAsBlock creates identical block definitions (RH-86146)
- CommandPrompt (Eto): Copy deletes selected text (RH-89214)
- Display: Direct3D: Display: D3D: Hatch Pattern in Block is Moved (RH-89419)
- Display: Options UI: Linetype on isocurves cannot be disabled (RH-89321)
- EdgeSrf: Made open 3-curve input always create 4-sided surface (RH-89363)
- ScriptEditor: Replace does not work with a space (RH-89349)
Cosmetics:
- Annotation: Styles: Term Inconsistency (RH-88598)
Enhancements:
- FilletSrf: Range: make it sticky (RH-89489)
- Grasshopper: Added Kerning and Line Spacing to Annotation Text Settings (RH-89366)
- ScriptEditor: Informs user when inputting an invalid path into headless Test Option (RH-89352)
- Section Tools: NestedClippingDrawings: Improve spacing (RH-89446)
Features Added:
UI Change:
- Print: Updated icon for Rhino PDF in Destination list (RH-89292)
Mac-Only Changes
Bugs Fixed:
- Aliases: Import dialog is stuck behind Options Page (RH-89347)
Windows-Only Changes
Bugs Fixed:
- Print: Rendered Environment background clipped in detail views (RH-89368)
- Rendering: Render content panels unusable in Tree mode (RH-87416)
brian
(Brian Gillespie)
62
Rhino 9 WIP (9.0.25266) is now available for Windows and Mac
Bugs Fixed:
- Command history may not scroll to the last line (RH-88910)
- Wrapping Problem (RH-89485)
- fillet srf changes view mode (RH-89391)
- Transparency during dynamic draw (RH-88552)
- GCon: Reports periodic curve to be non-tangent (RH-89534)
- GlobalEdgeContinuity: Filter out singularities from results (RH-89339)
- Linetype: Curve is Drawn where Shape Is (RH-88905)
- Patch: Dialog now remember the settings (RH-88994)
- ScriptEditor:
- SVG Editor: Updated resvg to a newer version (RH-84377)
Enhancements:
- ContentBrowser: 'Choose Existing' content dialog improvements (RH-89552)
- MatchSrf: Added OnSurface option to first prompt (RH-48653)
UI Change:
- Patch: "Remove constraints" button is not discoverable (RH-87224)
Bugs Fixed:
- CommandPrompt (Eto): Right-click clears text highlight (RH-89406)
- Shadows are affected by material settings… (RH-89560)
- Separate back face material in Rendered mode crashes (RH-89551)
- Windows ARM machines crash when opening specific file (RH-89524)
brian
(Brian Gillespie)
63
Rhino 9 WIP (9.0.25273) is now available for Windows and Mac
Bugs Fixed:
- ClippingDrawings: Projection always resets to Parallel (RH-89607)
- Edge color gets reset (RH-89624)
- Color backface does not work in Display panel (RH-89601)
- Mirror: Mirror creates bugged object (RH-89458)
- OSnap: Quad and Mid don't show simultaneously (RH-89604)
- SoftTransform: SoftTransform should work with cage objects (RH-89452)
- Thickness: Allow More Decimals (RH-89564)
- Zebra: Removed "Distance" mode as it could not reveal discontinuities (RH-89635)
Enhancements:
- Drag Settings: Made Soft Transform work with UVN mode (RH-56770)
- File IO: SketchUp Export - Added "Group objects" option to make selecting objects in SketchUp easier (RH-89556)
Features Added:
- ClippingDrawings: Added Projection=Reflective for drawing Reflected Ceiling Plan (RH-77428)
Regressions Fixed:
- SelName: [Enter] does not close the dialog (RH-89656)
Usability Problems Fixed:
- ScriptEditor: Right-click cut, copy, paste in Script Editor for Windows (RH-79242)
Bugs Fixed:
- Inverted inactive technical detail views with shadows… (RH-89647)
- Normal map producing wrong results for transparency (RH-89573)
- Some isocurves missing on NetworkSrf preview surface (RH-89431)
brian
(Brian Gillespie)
64
Rhino 9 WIP (9.0.25280) is now available for Windows and Mac
Bugs Fixed:
- CommandPrompt resizing in Search mode (RH-88400)
- CommandPrompt: Missing colon after prompt (RH-88792)
- Command History missing option values (RH-88827)
- Display:
- Dynamic Black/White Switching (RH-89734)
- Ghost image of Raytraced view after switching display mode (RH-87821)
- Display: D3D: Details are Opaque (RH-88999)
- Markup: Markup panel from markups table (RH-89767)
Enhancements:
- Clipboard: Add Text Content (RH-89678)
- Display: Crosshairs automatically switch between black and white based on viewport background brightness (RH-89741)
- File IO: SketchUp Export - Added IncludeUnweldedEdges option for merging joined planar adjacent faces (RH-89627)
Mac-Only Changes
Bugs Fixed:
- Annotation: Hatch: Mac version missing additional default patterns (RH-88568)
- Elmo command cannot complete on Mac (RH-88912)
- Backspace Does Not Delete (RH-88313)
- Commands display two dialog boxes (RH-88748)
- Layer: Some keys open System functions after activating a layer as current (RH-81975)
Bugs Fixed:
- Display: Direct3D: Ground plane does not clip with Shadows-only on (RH-89740)
brian
(Brian Gillespie)
65
Rhino 9 WIP (9.0.25287) is now available for Windows and Mac
Bugs Fixed:
- CommandPrompt (Eto): Instant Alias does not work (RH-88856)
- Display:
- Offset Preview Color Needs Adjustment for Black Background/Black Highlight (RH-89863)
- Black Background and Black Highlight Issue (RH-89862)
- Display: D3D: Line not visible head-on (RH-88174)
- Miter rendering in Direct3d is off (RH-88862)
- Emap:
- scrollwheel to cycle through Emaps (RH-89912)
- Add a ‘restore’ button to the Emap dialog (RH-89759)
- Markup:
- Markup panel from markups table (RH-89767)
- Eraser preview isn’t visible (RH-88534)
- Options: The more display modes exist, the longer Options dialog takes to open (RH-86636)
- Print: Transparent background (RH-10758)
- Rebuild: Add RebuildOld command (RH-89860)
- Reflect:
- Symmetry line thickens with z height (RH-87298)
- SubDReflect line appearance (RH-89840)
- Rendering: Textures: Rendering Texture: Search Cancel icon needs to be red instead of gray (RH-89776)
Crashes Fixed:
- Squish: Running Squish with SplitSeams=No causes Rhino to crash (RH-89646)
Enhancements:
- ClippingDrawings:
- Add Properties option (RH-89913)
- Use reference layers to apply properties (RH-89905)
Features Added:
- Display: IsolateToViewport Command (RH-87733)
Mac-Only Changes
Bugs Fixed:
- CommandPrompt: Wrong command is fired (RH-87354)
- CommandPrompt (Eto): Block Abbreviated to "B" (RH-89780)
- SetView:
- SetActiveViewport command doesn’t change viewport (RH-89857)
- SetActiveView should bring view to focus (RH-89853)
brian
(Brian Gillespie)
66
Rhino 9 WIP (9.0.25294) is now available for Windows and Mac
Bugs Fixed:
- CommandPrompt (Eto): Search command UI no longer docked after update (RH-89928)
- Display: Per-Viewport Visibility: RhinoCommon Access (RH-89977)
- Drag Settings: Soft Transform not working with cage without captive object (RH-89750)
- Gumball: Direction of approach to ctrl pt changes alignment of GB (RH-89544)
- GumballAlignment: Handles don't line up with UVN (RH-89370)
- IsolateToViewport: Objects invisible in other viewports display when dragging (RH-89943)
- Markup:
- Panels: NamedView: No scroll bar in Named View panel (RH-90023)
- Rendering: Texture Mapping: Texture mapping rotation spinner captures too many undo markers (RH-89798)
- SDK: RhinoCommon: Squish: unable to obtain the correct result (RH-89644)
- Selection: Create a SelIsolated command (RH-89938)
- ShowEnds: "Zoom" button missing behavior (RH-90021)
- SoftTransform:
- Shouldn’t draw meshes in wireframe mode (RH-89453)
- Drag Settings: Falloff radius at 0 shows black shade (RH-89676)
- Allow sphere select for SoftTransform radius (RH-89483)
- Zebra: cannot change all colors (RH-89127)
Enhancements:
- ClippingDrawings:
- Add Points Layer Under Section (RH-90001)
- ClippingDrawings - Output Separate Boundary Curve (RH-89858)
- EvaluatePt: Added OmitZeroZCoordinate option when Label=On (RH-88521)
- Isolate: oViewport: Allow Enter for Active Viewport (RH-89954)
- Section Tools: ClippingDrawings: Add draworder to output (RH-77443)
- Zebra: Added static X, Y, Z buttons (RH-89997)
Features Added:
- Display: IsolateFromViewport (RH-89874)
- Section Tools: Add tangent edges (RH-78044)
SDK Enhancement:
- SDK: Added double-click support to .NET UI objects (RH-89970)
UI Change:
- Markup: Default line width should be thinner (RH-89932)
Mac-Only Changes
Bugs Fixed:
- Emap: Hidden image import dialog locks Rhino app (RH-89988)
- Grasshopper: Zoom and UI issues on Mac (RH-89941)
- UI Appearance: Slider brings focus back to Rhino on Mac (RH-89924)
Regressions Fixed:
brian
(Brian Gillespie)
67
Rhino 9 WIP (9.0.25301) is now available for Windows and Mac
Bugs Fixed:
- File IO: Saving during command fails silently (RH-90070)
- Linetype: Linetypes panel refresh after ModifyLinetype (RH-90042)
- Markup:
- Tapered curves appear thinner when erased (RH-90082)
- Markup selection control showing up in other viewport (RH-90123)
- SubD: SubD curvaturegraph for selected edges only (RH-76806)
- Undo: Make RedoSelection stack more persistent (RH-89357)
Crashes Fixed:
- Annotation: Hatch: Section Style hatch pattern crash. (RH-90196)
Enhancements:
- ClippingDrawings: Add a AutoUpdate=Yes|No Option (RH-90008)
Features Added:
- Audit: dmFile: Audit Summary tab (RH-89074)
- Isolate: oViewport: Allow Visibility in Multiple Viewports (RH-89968)
- Toolbar: Add IsolateToViewport Button (RH-89869)
brian
(Brian Gillespie)
68
Rhino 9 WIP (9.0.25308) is now available for Windows and Mac
Bugs Fixed:
- BooleanDifference: Boolean Difference makes polysurface with non-manifold edge (RH-37066)
- CommandPrompt (Eto): Autocomplete cannot be temporarily canceled (RH-90062)
- Join: Sweep1 results in bad objects (RH-90215)
- Markup: Double-clicking slider should not change number (RH-90252)
- Selection:
- UndoSelection: controlpoints (RH-90211)
- UndoSelection reports a selection that have been deleted (RH-90210)
- SoftTransform:
- SoftTransform moved grips should be drawn (RH-89360)
- Z-fighting between edges and faces in smooth display mode (RH-90201)
Enhancements:
- Annotation: Hatch: Allows deleting multiple in-use patterns at once (RH-90112)
- ClippingDrawings: Use reference layers to apply properties (RH-89905)
Regressions Fixed:
- BooleanDifference: Boolean fail (RH-88311)
UI Change:
- Changed scaling type dropdown to tabs (RH-90079)
- Added scaling slider and List View mode (RH-90182)
- Sweep1: Removed roadlike axis vector coordinates from prompt (RH-90212)
Mac-Only Changes
Bugs Fixed:
- utosave: Setting to toggle macOS Autosave/Versions (RH-71881)
- CommandPrompt (Eto): Cannot toggle Sidebar on Mac (RH-89735)
- Patch: Garbage surface with Molded domain option (RH-89925)
brian
(Brian Gillespie)
69
Rhino 9 WIP (9.0.25315) is now available for Windows and Mac
Bugs Fixed:
- Annotation: Hatch: Right-click may not show correct context menu in List view (RH-90277)
- ClippingDrawings: Background without the Section (RH-90319)
- File IO: DWG: Export Not Including Text Mask (RH-73565)
- Join: Sweep1 creates unjoinable polysurface (RH-90361)
- Markup:
- Filled hatch in markups (RH-90300)
- Description/Comments field for markups (RH-90267)
- Dimensions in markup (RH-90299)
- Save and cancel buttons left tooltips on screen (RH-90307)
- Options: Display Mode Disappears from List (RH-90316)
- Section: Fails for SubDBox with TestPlaneBrepNew (RH-90151)
- Selection: UndoSelection: controlpoints (RH-90211)
- SoftTransform:
- SoftTransform fall off color should be saved between Rhino sessions (RH-89480)
- SoftTransform should shade the captive objects in cage (RH-90291)
- Undo: Undoing groups is extremely slow (RH-90088)
Enhancements:
- Group: Global group selection controllable (RH-1045)
Features Added:
- Annotation: Leader: User text aware Tag (RH-87137)
- ClippingDrawings: Auto-Isolate to Layout (RH-90007)
- File IO: Export - Transparent background of layouts and details (RH-66636)
SDK Enhancement:
- Markup: Creates markup objects on special hidden layers (RH-87227)
- SDK: RhinoCommon: Added Mesh Cage Edit Logic (RH-89427)
UI Change:
- Toolbar:
- Added More (…) button to New in V9 toolbar (RH-90317)
- Added New Audit 3dm file button to New in v9 Toolbar (RH-90280)
- UI Appearance: ThicknessAnalysis: UI tune-up (RH-90239)
Mac-Only Changes
Bugs Fixed:
- File IO: Spinners in STL mesh export detailed options are not wide enough (RH-90355)
- PointDeviation: Quitting panel on Mac does not disable the PointDeviation analysis (RH-90303)
- UI Cleanup:
- Splash Screen extends off the screen with Liquid Glass (RH-90328)
- UI: LiquidGlass: Sweep2 dialog radio buttons are touching each other. (RH-90344)
- UI: LiquidGlass: SetCurrentAnnotationStyle: touching buttons (RH-90346)
- LiquidGlass: NetworkSrf.xib: overlapping buttons (RH-90333)
- LiquidGlass: Heightfield (RH-90342)
- LiquidGlass: OrientOnSrf: overlapping buttons (RH-90343)
- LiquidGlass: Weight: touching buttons (RH-90345)
- LiquidGlass: ModelingAids: SmartTrack tab (RH-90350)
Bugs Fixed:
- Markup: "(null)" in exported image file names (RH-90311)
- Rendering: Vray for Rhino no longer loads (RH-90313)
brian
(Brian Gillespie)
70
Rhino 9 WIP (9.0.25322) is now available for Windows and Mac
Bugs Fixed:
- The contrast of the content ui's are quite high. (RH-83954)
- Creating a hatch clears previous undo stacks (RH-90457)
- Patterns cannot be deleted (RH-90249)
- Hatch properties can not stick to “All Hatches” (RH-90448)
- ClippingDrawings:
- Eto: Do not let right-click trigger rename in list mode (RH-90384)
- Help: for Patch: internal constraints (RH-90137)
- MissingAssets: Tringle icon is getting clipped (RH-90389)
- Options: Display Mode options look different on Mac vs. Windows (RH-87991)
- PackageManager: Packages should be curated (RH-89937)
Enhancements:
- Align: Align Will Not Use InfinitePlane (RH-90437)
- ClippingDrawings: Output hatch inherits clipped object's section style properties (RH-89775)
- Rotate3D: Allows using a curve segment to define rotation axis (RH-90365)
- ShowDir: Better UV indicators (RH-56040)
Mac-Only Changes
Bugs Fixed:
- Annotation: Hatch: Grid and list view icons don't fit on Mac (RH-90467)
- Interface: Missing Assets - font list not updating after BulkReplace (RH-90340)
- OSnap:Dialog: OSnap: Dialog: Control Provides Inaccessible Options (RH-90223)
- UI Cleanup:
- LiquidGlass: Step Import Options: Padding (RH-90353)
- LiquidGlass: Acad Import: touching radio buttons (RH-90352)
- LiquidGlass: BlendSrf: misaligned radiobuttons (RH-90348)
- UI: LiquidGlass: ModelingAids: Gumball Tab (RH-90349)
Bugs Fixed:
- Annotation: Hatch: Current pattern name displays with different font weight (RH-90449)
- Menu: Recent files - include rws files (RH-34856)
brian
(Brian Gillespie)
71
Rhino 9 WIP (9.0.25323) is now available for Windows and Mac
Bugs Fixed:
- ClippingDrawings: Hidden is Dashed instead of Hidden (RH-90529)
- Display: Options UI: Custom lighting: Color pickers don't work (RH-90469)
Enhancements:
- File IO: SketchUp Export - Added IncludeUnweldedEdges command-line option for merging joined planar adjacent faces (RH-89627)
- Smooth: Preview points (RH-55455)
brian
(Brian Gillespie)
72
Rhino 9 WIP (9.0.25329) is now available for Windows and Mac
Bugs Fixed:
Enhancements:
- ClippingDrawings: Support Selecting Multiple Viewports in IsolateToViewport option (RH-90539)
Features Added:
Mac-Only Changes
Bugs Fixed:
- UI Cleanup:
- UI: LiquidGlass: BlendCrv misaligned radiobuttons (RH-90341)
- UI: Liquid Glass: TextOut dialogs lacks LG compatible constraints (RH-90509)
- UI: Liquid Glass: Settings > General - Privacy Label truncated (RH-90512)
brian
(Brian Gillespie)
73
Rhino 9 WIP (9.0.25343) is now available for Windows and Mac
Bugs Fixed:
- Canceling “Add Hatch To File” dialog still adds a pattern (RH-90898)
- Solid pattern can be renamed in grid view (RH-90892)
- Match Not Working (RH-90622)
- All default patterns return when opening a saved model (RH-90490)
- Counting incorrectly for multiple selection (RH-90611)
- Selecting another pattern when editing name does not accept new name (RH-90521)
- Arctic display: Displays colorful shading instead of pure white (RH-90691)
- Audit:
- dmFile: Scriptable version should do what old commands do (RH-89338)
- dmFile: Audit Unsaved Open File (RH-89409)
- ClippingDrawings: Ignore Hidden Objects (RH-90678)
- CommandPrompt: Port Mac command line UI to Eto (RH-29372)
- Issues with docked search bar options (RH-90759)
- Tab Direction Lock fails (RH-90743)
- Shows an empty tooltip in Search mode (RH-90665)
- CommandPrompt:Bug with command option switches (RH-90740)
- Connect: Do not attempt to connect two nearly overlapping parallel lines with double doc tolerance (RH-90695)
- ContentBrowser: Start from existing dialog may be hidden and locks Rhino app (RH-90652)
- Display: Patch command doesn't refresh evaluation dots in viewports (RH-90742)
- Advanced GPU lighting makes all materials black (RH-90845)
- Zebra single backface color inconsistent (RH-90381)
- Display modes: Can’t reset to defaults (RH-90763)
- Technical/Artistic/Pen shown as non-default after factory reset (RH-90650)
- Incorrect layout in Custom Lights dialog (RH-90358)
- ExtractSrf: OutputLayer option is ignored for SubD surfaces (RH-80987)
- Grasshopper 2: Release date is incorrect (RH-90099)
- History: DimAligned Relocates (RH-90764)
- Join: Brep.JoinBreps gives two invalid Breps (RH-81670)
- Markup: Black thumbnail background (RH-90849)
- NamedView: Double-clicking to restore no longer work (RH-90647)
- Patch: Continuity dots not visible in viewports (RH-90720)
- Rendering: Fixed wrong window location and size on external 4k monitor for RenderWindow command (RH-90138)
- Rendering: Materials: Name editing box extends beyond panel (RH-90761)
- SelBlockInstanceNamed: SelectBlockInstanceNamed: Missing feature for preselection (RH-90926)
- Selection:
- Chain select and locked/hidden SubD subobjects (RH-90951)
- Crossing selection may not select entire group (RH-90925)
- SelGroup: Dialog does not appear when non-grouped objects exist (RH-90924)
- SimplifyCrv: Curve doesn't simplify (RH-90735)
- SoftTransform: Tune up SoftTransform command to run consistently (RH-89482)
- SubD: hide subd faces (RH-66737)
- UI Appearance:
Crashes Fixed:
- Crash on launch (RH-90868)
- Crash: Rhino WIP Undo Crash (RH-90586)
- Units: Changing units with scaling hangs Rhino (RH-90866)
Enhancements:
- Audit:
- Audit3dmFile: Added Filename to Title Bar (RH-89394)
- dmFile: Allows canceling long-running progress (RH-88756)
- ClippingDrawings: Use TemplateLayers when UseSourceLayer (RH-90243)
- Connect: Made Fillet/Chamfer/Connect support extensions shorter than absolute tolerance (RH-90694)
- Display: Options UI: Changing custom lighting updates viewports interactively (RH-90469)
- MissingAssets: Display tooltip when model loads with missing assets (RH-90697)
Features Added:
- Core Architecture: Added SectionStyle table to Rhino document (RH-74286)
- Display: Weighted points to look different (RH-21211)
- GrasshopperBlocks: Grasshopper: Export Block does not support 3MF (RH-90722)
- Scale: New ScaleEach command (RH-68441)
Regressions Fixed:
- Offset: Curve Regression Sample (RH-88434)
- Toolbar: Selecting "Curve Tools" tab does not update sidebar (RH-89578)
UI Change:
- Uses a popup for selecting pattern (RH-90431)
- Cannot rename with a double-click (RH-86677)
- Options: Icons in File Explorer and Libraries pages need an update (RH-90802)
- Toolbar (New): Allows setting button padding from 1 to 5 (RH-90639)
- Angle: Masks numerical noise from the reported angle (RH-90680)
Mac-Only Changes
Bugs Fixed:
- Name editing box hidden behind dialog (RH-90519)
- Renaming a default pattern creates a copy (RH-90520)
- SoftTransform: Softtransform: Display lockup / endless loop (RH-90701)
- Toolbar (New): Main sidebar is empty (RH-90672)
- UI Cleanup:
- Liquidglass: PLY export: touching radio buttons (RH-90768)
- LiquidGlass: ACIS export: touching buttons (RH-90769)
- Liquidglass: LWO export touching buttons (RH-90767)
- Liquidglass: FBX export (RH-90766)
Bugs Fixed:
- CommandPrompt (Eto): Tapping Alt key after entering a value disables OSnaps (RH-90643)
- Display: Direct3D: Back Face Display Issue (RH-90714)
- Section Style: Prompts twice when deleting in-use section styles (RH-90895)
- Toolbar (New):
- Hovering mouse cursor over toolbar causes icon background to flicker (RH-90561)
- Searching in Show toolbars list locks Rhino (RH-90632)
Regressions Fixed:
- CommandPrompt (Eto): F2 Focus (RH-90803)
brian
(Brian Gillespie)
74
Rhino 9 WIP (9.0.25350) is now available for Windows and Mac
Bugs Fixed:
- tretchDisplay: set bounds (RH-91050)
- tretchDisplay: allow compression (RH-91049)
- Text size of command prompt does not work (RH-88869)
- Background color cannot be changed (RH-88525)
- Display: BackFace of Partly Hidden SubD (RH-91015)
- Grasshopper: Save/Restore State on widgets is not working correctly (RH-91037)
- Properties: Add "Edit DimStyle" to ClippingPlane Properties (RH-90506)
- Selection: Edges of Hidden SubD Faces (RH-91014)
- TextField: Text fields- Volume - ignores dimstyle units (RH-67437)
Bugs Fixed:
- RhinoUserInterfaceObject Animation doesn't work on windows (RH-86395)
- CommandPrompt (Eto): Font size and colors cannot be changed (RH-88404)
- Display: Direct3D: Selection window does not align with mouse cursor (RH-90173)
- Properties: Pressing Enter when editing object name repeats last command (RH-90953)
Crashes Fixed:
- Audit: dmFile: Browse option crashes on Windows (RH-91043)
dan
(Dan)
75
Rhino 9 WIP (9.0.25357) is now available for Windows and Mac
Bugs Fixed:
- Annotation: Leader: Handle double click on UserTextLeader dialog (RH-91137)
- BlendEdge: MultiBlend Shape (RH-91055)
- ClippingPlane:
- Display: Direct3D: Point Cloud Performance Issue (RH-90644)
- Eto: Slider values are invisible (RH-91161)
- GlobalEdgeContinuity: Outline of surface hidden by isolation remains visible (RH-85959)
- Gumball: UVN gumball should create U and V alignment for SubD vertices if possible (RH-91153)
- Markup: Markup in active detail (RH-91196)
- Rendering: Environments: Thumbnail stretched when returning from horizontal layout (RH-89535)
- Toolbar (New):
- Toolbars: Button is showing wrong image (RH-90800)
- MMB menu icons change / no toolbar (RH-90558)
- RMB-repeat does not work correctly anymore (RH-90945)
- Left Side bar doesn’t switch (RH-90545)
- Left side bar is empty (RH-90747)
- Sidebar tabs (RH-90754)
Cosmetics:
- UI Cleanup: Light Panel color swatch should be square (RH-91111)
Enhancements:
- File IO: Navisworks: Navisworks updates: 19-Dec-2025 (RH-91189)
- UVEditor: Allows selecting sub-faces in model space based on selected UV islands (RH-91095)
Features Added:
- OSnap: Allows End and Near snapping to the polyline being drawn (RH-91021)
Regressions Fixed:
- Grasshopper 2: Py3 scripts process error (RH-91125)
- Markup:
- Markup Eraser broken (RH-91205)
- Numeric entry for UI slider, wrong position (RH-91204)
SDK Enhancement:
- SDK: Added function to convert a Brep to an Extrusion (RH-54045)
UI Change:
- Layout: Make Set Active Layout/Detail Nestable (RH-90817)
- SubD: Hide edges when the faces they connect are hidden (RH-91047)
Mac-Only Changes
Bugs Fixed:
- Display Metal: Hiding faces of a closed SubD temporarily culls back faces on Mac (RH-91148)
Regressions Fixed:
- Picture: Scaled Incorrectly on Mac (RH-91104)
Bugs Fixed:
- Not working with Picture command (RH-91142)
- Raytraced mode needs overlay support (RH-91096)
brian
(Brian Gillespie)
76
Rhino 9 WIP (9.0.26006) is now available for Windows and Mac
Bugs Fixed:
- ClippingPlane: Dot off line (RH-91237)
- Explode: Skip preview step if tangent components don't exist (RH-91256)
- GlobalEdgeContinuity: Zoom slider clipped (RH-91228)
- Rendering: Materials: Thumbnail Preview Properties doesn't load from default (RH-91056)
- Selection:
- SubD crossing selection (RH-91250)
- Clicking hidden/locked SubD edges selects object (RH-91247)
- SubD: Sub-objects hidden/locked when edit/control points on do not remain their states (RH-91170)
Enhancements:
- Sun: Added "Current location" and "More settings" buttons to Sun properties in Lights panel (RH-81705)
Bugs Fixed:
- Display: Direct3D: Last Rendered view remains in Zebra stripes (RH-91227)
brian
(Brian Gillespie)
77
Rhino 9 WIP (9.0.26013) is now available for Windows and Mac
Bugs Fixed:
- Annotation: Hatch: Hatch pattern page blows up (RH-91119)
- Audit: Audi: Audit3dmFile: Thumbnail/PreviewImage should have a separate entry (RH-88759)
- ClippingPlane:
- File IO: No "Always use these settings" warning for DXF export (RH-91290)
- Layout: Remember Last Number (RH-88616)
- Markup:
- Display markup geometry only in active viewport (RH-86578)
- Markup Line tool (RH-91420)
- Drag markup objects in view plane (RH-91345)
- Arrows don’t show up on tapered curves (RH-90012)
- Patch:
- MultiMatch issues from V9 (RH-89403)
- F1 key opens wrong command topic (RH-88595)
- ScriptEditor:
- Save Before Execute in GH components (RH-89909)
- Save button on Project Publish should not close (RH-89315)
- SDK: RhinoCommon: Removed Curve.RebuildElmo (RH-90275)
- SoftTransform: SoftTransform distance measures should be two radio buttons and not a drop down (RH-91152)
- Toolbar (New):
- UVEditor:
Cosmetics:
- ScriptEditor: ScriptEditor Open File dialog should say "Open File" (RH-84118)
Crashes Fixed:
- Rendering: Show Distance Channel crash (RH-90089)
Enhancements:
- Annotation: Styles: Add Clipping-Plane Arrows to Annotation Styles (RH-90911)
- Layout: Add Status Bar To Layout Panel (RH-91341)
- Markup:
- Write CRhinoDoc::MarkupTable to 3dm file (RH-89907)
- Suspends modeling aids (RH-88194)
- Mirror: Enhancements: Object Should Pick Line (RH-91263)
- Patch: add a way to immediately cancel the calculation (RH-89762)
- ScriptEditor:
- Highlight context marker when editor pauses on a new context in debug (RH-85522)
- Group dunder variables under ‘private’ (RH-85523)
- Search & Replace is not persistent between sessions (RH-89116)
- Create new file types other than cs or py in ScriptEditor (RH-84117)
- Support adding, removing, and renaming tests in Test Panel (RH-85686)
Features Added:
- ScriptEditor: Support Tests in Project? (RH-87044)
- Emap: Needs to show names of EMaps (RH-90024)
- Markup: Continue a markup (RH-87273)
- ScriptEditor: RhinoCode Editor: Provide a way to list open files (RH-86545)
Mac-Only Changes
Bugs Fixed:
- Patch: Nesting command causes a crash on Mac (RH-91344)
- Toolbar (New):
- Panel popup takes an extra click (RH-90758)
- RUI explorer: beach ball with undo (RH-90550)
brian
(Brian Gillespie)
78
Rhino 9 WIP (9.0.26019) is now available for Windows and Mac
Bugs Fixed:
- Annotation: Hatch: Pattern list blows up (RH-91119)
- GlobalEdgeContinuity: Show lower level results in all modes (RH-91510)
- Layer: Multiple layers selected, only one layer changes (RH-91354)
- Localization: ArrayCurve localization duplicate (RH-91527)
- Markup:
- NamedView: Viewport name * not shown when it should be (RH-91064)
- Nudge: Nudge on Solid Pts fails quickly (RH-91252)
- Patch: History does not work anymore (RH-91478)
- Selection: Allow Selection of Visible Control Points (RH-91359)
- UVEditor: Incorrect edges highlighted in model viewport (RH-91347)
Enhancements:
- ClippingDrawings:
- EditClippingDrawings: Provide a Version with a Dialog (RH-90006)
- UVEditor: Highlight selected sub-objects in model viewports (RH-72383)
Features Added:
- Annotation: Wish: Tab Support in Text (RH-19590)
- Display: Promote TestShowKnots (RH-91541)
- File IO: create import for USD (RH-78662)
- Guides: Toggle Guides visibility (RH-43040)
Regressions Fixed:
SDK Enhancement:
- SDK: Allows deleting multiple hatch patterns (RH-87590)
UI Change:
- ClippingSections: IsolateToViewport Enhancement (RH-90420)
Mac-Only Changes
Bugs Fixed:
- Grid: Active Viewport is Always Perspective (RH-91357)
- LoadPlugin: 3DConnexion legacy switching not working on Mac (RH-91388)
Bugs Fixed:
- Audit: Audit3dmFile only works once in a Rhino session on Windows (RH-91410)
- Display: D3D: Hatch Drawn on Top (RH-91481)
- Display: D3D: Select In Detail (RH-88935)
brian
(Brian Gillespie)
79
Rhino 9 WIP (9.0.26027) is now available for Windows and Mac
Bugs Fixed:
- ArrayCurveAdvanced: Cylinders may shade as boxes (RH-91794)
- ClippingDrawings: Names of Non-Section Objects (RH-91753)
- Display:
- Linetype Scaling for Annotations (RH-91087)
- Displaying selected elements takes too long (RH-90869)
- Display: D3D: Incorrect Linetype Display (RH-91756)
- Display: D3D: Text Hops on Selection (RH-91767)
- Gumball: Can we have a Snappy/Smooth toggle? (RH-25676)
- Markup: "RevCloud" command does not repeat (RH-88601)
- SoftTransform:
- fall off by point count (RH-90571)
- Add boundary constraints to SoftTransform options (RH-90983)
- Text: Text should support superscript and subscript (RH-35493)
- Toolbar (New):
- Toolbar flyout, buttons - mouse event passes through (RH-91516)
- Pumpkins (RH-91622)
- Escape button and maybe right click deleted button? (RH-91584)
- Toolbar Tabs required? (RH-91040)
Enhancements:
- Annotation: Styles: Wish: Datum arrowhead for annotations (RH-90017)
- ClippingDrawings: EditClippingDrawings: Dynamic Feedback Improvements (RH-91697)
- Installer: Worksession .rws unique icon (RH-91131)
- Markup:
- Any Markup* command should launch Markup (RH-91503)
- Maintain markup slider values between runs (RH-87489)
- markup line type in the default linetype list (RH-89228)
- markups retain line style and width (RH-89102)
- Patch: Preserve edges with starting surface (RH-87232)
- ScriptEditor: Search & Replace is not persistent between sessions (RH-89116)
Features Added:
- ArrayCurveAdvanced: New ArrayCurve command, prototype for arraying object / block along curve (RH-84485)
- Guides:
- Select linear curves (RH-50134)
- Added GuideArray option to AddGuide command (RH-39959)
Regressions Fixed:
- Text: Text Control Points Not Changing Text Width (RH-91562)
- ScriptEditor: Allow debugging without breakpoints in main code (RH-85988)
Bugs Fixed:
- Display: Annotation Hatch: "Use Layout Scaling" does not trigger update in detail views (RH-86802)
Regressions Fixed:
- Grasshopper 2: Error message when loading GH2 (RH-91751)
brian
(Brian Gillespie)
80
Rhino 9 WIP (9.0.26035) is now available for Windows and Mac
Bugs Fixed:
- Audit3dmFile:
- Better colors for UserData and other types (RH-91966)
- Layers lack names (RH-91965)
- Handle Markup Tables and Types (RH-91964)
- Progress Bar (RH-88755)
- Command option can’t be used with underscored letter (RH-89373)
- File IO: File I/O: Preview images are too big (RH-91809)
- GeometricTolerance: "Dash" Needs Additional Formatting (RH-92043)
- Grasshopper: The Clipped Drawing component fails if an object doesn't contain a valid section style (RH-92032)
- Gumball:
- Gumball snappy/smooth toggle while dragging should be one shot (RH-92019)
- Make smooth/snappy toggle easier to hit while dragging (RH-92017)
- Markup: Icon readability issue (RH-91691)
- ScriptEditor:
- API search doesn’t fold out results (RH-89268)
- Python big integers break variables in debugger (RH-85876)
- Help python libs are missing when only python 3 is loaded (RH-91635)
- AutoComplete doesn’t show arguments (RH-89269)
- SDK: RhinoCommon: Rhino.UI.Controls.ViewportControl does not dispose view on Windows (RH-91825)
- Toolbar:
- Moving toolbar tab prints debug text to command window (RH-91968)
- What is defaultmac.rui for? (RH-89829)
- Toolbars Name is wrong in Toolbars Menu (RH-89817)
- Toolbars is not wired up right (RH-89818)
- Toolbar (New):
- Toolbar: Toolbar buttons are empty (RH-90799)
- Options button uses a wrong icon (RH-90917)
- Toolbars: Button showing wrong image (RH-91439)
- Options button disappears (RH-91424)
- New Button should open edit button dialog (RH-91514)
- Tear-off: make size exact (RH-90555)
- New “New Button” dialog is V8 style (RH-91469)
- Macros library shows on running command but should not (RH-91585)
Cosmetics:
- ScriptEditor: Fix text and icon color over selected items (RH-85521)
Crashes Fixed:
- ScriptEditor: -rs. ListBox() fail (RH-79693)
Enhancements:
- Arc: Arc startpoint, endpoint, height/direction (RH-89561)
- Audit3dmFile: Rhino Minor Version (RH-91537)
- ScriptEditor: Improved Author editing in Projects (RH-85680)
Features Added:
- Grasshopper: Components: Ship ShapeMap with Rhino (RH-89917)
- Patch: Updated Continuous Patch Grasshopper component to new UI (RH-86873)
- ScriptEditor:
- Code formatting for C# (RH-80477)
- Output geometry from scripts is missing preview (RH-88284)
Incomplete Port:
- Toolbar (New): Look @ Diff Files (RH-91366)
Performance Improvements:
- Audit3dmFile: ChunkDump for quick initial pass (RH-91501)
UI Change:
- Markup: : Removed icon transparency (RH-91870)
- ScriptEditor:
- Make it more clear that script being debugged is Read-only (RH-81639)
- Allows edit while debugging (RH-90882)
Bugs Fixed:
- Markup: HUD slider gets stuck on Windows (RH-87786)
