Rhino BETA Available Now!
Rhino 9 WIP (9.0.25091) is now available for Windows and Mac
Bugs Fixed:
  • Annotation: Hatch:
    • “Fill Style” in hatch creation dialog has a “varies” (RH-86753)
    • Resize hatch creation dialog (RH-86752)
    • Import - No to all equals Cancel (RH-73427)
    • Pattern thumbnail may not match the container (RH-86755)
    • “varies” for display color may not display (RH-86754)
  • Annotation: Styles: "Line space scale" missing label (RH-86716)
  • File IO: General options clipped in AutoCAD export dialog (RH-86738)
  • TextObject: Dialog doesn't show new settings (RH-86718)
Crashes Fixed:
  • FillSrf: Command: System.DllNotFoundException: UnsafeNativeMethods.ON_UserData_RegisterCustomUserData (String managedTypeName, Guid managedTypeId, Guid classId) (RH-86749)
Enhancements:
  • FillSrf: FillSrf - automatic splitting of edges to make a closed loop (RH-86008)
Features Added:
  • OSnap: Restrict picks to snapped ones (RH-75012)
Windows-Only Changes
Bugs Fixed:
  • New: Suggests NonExisting File (RH-86592)
Rhino 9 WIP (9.0.25099) is now available for Windows and Mac
Bugs Fixed:
  • FillSrf:
    • Fails to trim surface (RH-86889)
    • No untrimmed option (RH-86887)
    • Zebra preview does not follow Zebra show on/off (RH-86825)
    • No history update for Extrusion objects (RH-86874)
    • Preview refresh rate drops with Zebra analysis (RH-86844)
Enhancements:
  • Layer: Added Purge button to Layers panel (RH-86905)
Features Added:
  • Annotation: Hatch: Allows creating a hatch by clicking on a planar surface (RH-2060)
SDK Enhancement:
  • SDK: RhinoCommon: Added a new CRhinoObjectAnalysisModeChanged event watcher (RH-86860)
Rhino 9 WIP (9.0.25105) is now available for Windows and Mac
Bugs Fixed:
  • FillSrf: Merged tangent edges - result different in FillSrfOld (RH-86995)
Enhancements:
  • Annotation: Hatch: Added 'Import' button to 'Select Hatch Pattern' dialog (RH-86997)
Features Added:
  • DocumentProperties: Added Section Styles page (RH-86100)
Rhino 9 WIP (9.0.25112) is now available for Windows and Mac
Bugs Fixed:
  • Annotation: Hatch: Extrusion faces are not pickable (RH-87072)
  • FillSrf: G0 surface edge - incorrect result (RH-87051)
Enhancements:
  • Annotation: DimAngle, DimRadius and DimDiameter allow selecting locked objects (RH-87001)
    • Prevents selecting non-planar curves and surfaces (RH-87052)
    • Supports creating hatches on different planes in a command session (RH-86917)
  • FillSrf: : specify an input surface (RH-86009)
Rhino 9 WIP (9.0.25119) is now available for Windows and Mac
Bugs Fixed:
  • File IO: DWG:
    • Deleting “Default” scheme causes a crash (RH-87164)
    • Scheme import does not update the dialog (RH-87163)
  • FillSrf:
    • Cannot edit sliders with double click. (RH-87145)
    • Button text is not clear (RH-87176)
  • Grasshopper: Invalid Box (RH-86595)
  • OffsetSrf: Gives junk results (RH-87128)
Features Added:
  • ClippingDrawings: Support Background Curves and Hatches (RH-85431)
  • File IO: DWG: Allows exporting print colors as DWG colors (RH-29332)
Mac-Only Changes
Bugs Fixed:
  • Section Style: Used section style gets deleted before prompt (RH-87155)
Cosmetics:
  • File IO: DWG: Options dialog on Mac updated to be Windows-like (RH-49034)
Rhino 9 WIP (9.0.25133) is now available for Windows and Mac
Bugs Fixed:
  • Display:
    • Direct3D does not draw annotation text (RH-86979)
    • Masked text interference (RH-52260)
  • File IO: DWG:
    • ‘Entities Only’ is available when not exporting R12 DXF files (RH-87359)
    • Two checkboxes can never be enabled (RH-87335)
    • Settings don’t save to default schemes (RH-87186)
    • Saving scheme shows ‘Name already in use’ (RH-87307)
    • Renamed scheme cannot be renamed or deleted (RH-87306)
    • Custom scheme cannot be renamed and deleted (RH-87284)
  • FillSrf: Editing patch created from merged edges does not work (RH-87222)
  • GlobalEdgeContinuity: Outline of surface hidden by isolation remains visible (RH-85959)
  • Grasshopper: Components: Hatch lines error (RH-87249)
  • Gumball: Allow rotate extend mode (RH-87360)
  • Layout: Text is obscured by mask settings in layout view (RH-54324)
  • Make2D:
    • make2D- Visible lines classified as hidden (RH-59101)
    • No output, no error message (RH-51474)
    • Silhouette clipped curves (RH-48092)
  • Offset: OffsetMultiple And Offset Need Same Options (RH-80801)
  • Section Style:
    • ‘Custom: Unnamed’ is not available after using doc style (RH-87242)
    • Settings are editable when no section style exists (RH-87181)
  • UDT:
    • LegacyStretch command does not allow selecting more or less control points (RH-87329)
    • LegacyStretch command applies double transform when both object and control points are selected (RH-87331)
Enhancements:
  • Annotation:
    • Draws text frame boundary above mask color to respect the width display (RH-61474)
    • Mask color supports transparency (RH-71772)
  • Elmo: Add support to rebuild a group of curves simultaneously (RH-82868)
  • File IO: DWG: AutoCAD scheme settings are saved on the fly (RH-87332)
  • FillSrf: remove upper limit on internal tolerance (RH-87391)
  • MoveEdge: Prevents creation of bad objects when planar faces are collapsed (RH-78708)
  • Properties: Add "Planar" descriptor to Object Properties for curves (RH-86756)
  • Toolbar: Toolbar Button for SetDetailBorder (RH-87376)
  • UDT: UTD: LegacyStretch command needs to highlight the control points to move (RH-87308)
Features Added:
  • ClippingDrawings: AddBackground option supports curves (RH-85431)
  • Text: Add support for text mask opacity (RH-35616)
SDK Enhancement:
  • SDK: RhinoCommon: Expose CRhinoDisplayPipeline::DrawInferenceLine to RhinoCommon (RH-85581)
Mac-Only Changes
Bugs Fixed:
  • FillSrf: GButtons don't refresh on Mac (RH-87256)
  • Text: Text doesn't support multiple lines (RH-87247)
Features Added:
  • Notes: Remembers text cursor location when Notes panel regain focus (RH-23213)
Bugs Fixed:
  • Display:
    • Direct3D does not fully draw curves (RH-87280)
    • Direct3d does not draw isocurves in wireframe mode (RH-87264)
  • Section Style: Settings become editable when no section style is selected (RH-87182)
Rhino 9 WIP (9.0.25140) is now available for Windows and Mac
Bugs Fixed:
  • Annotation: Hatch: 'Add Defaults' does not generate thumbnail for hidden patterns (RH-87425)
  • CurvatureAnalysis: Uses point as decimal separator (RH-87456)
  • GlobalEdgeContinuity: Handling of Split Edges against non split edges (RH-85864)
  • Markup: Allow pan/zoom on 2D markup (RH-87507)
  • Unwrap: symmetric objects should unwrap symmetrically (RH-85861)
  • Zebra: Stripes disappear from SubD when selecting a control point (RH-87410)
Cosmetics:
  • Icons: Swap positions of + and - on 'Add to point cloud' button (RH-87478)
Features Added:
  • UDT: New LegacyStretch command (RH-2260)
Rhino 9 WIP (9.0.25147) is now available for Windows and Mac
Bugs Fixed:
  • Display: D3D Non-Rectangular Detail is Not Clipped (RH-87405)
  • FilletSrf:
    • Preview is different from end result (RH-87341)
    • Unable to make spherical fillet (RH-87503)
  • Markup:
    • Button triggered when click initiated outside (RH-87474)
    • Disallow viewport change in markup (RH-86574)
    • Improving restoration process (RH-86369)
    • Exclude markup layers from Layers panel (RH-87226)
    • Osnaps are being used even though snaps are disabled (RH-86556)
  • MoveUVN: Falloff modes crash with curve control points (RH-87606)
  • SetDisplayMode: Ghosted mode transparency issue (RH-87625)
  • Unwrap:
    • Mesh unwrapped with poor accuracy (RH-62042)
    • Conformal produces infinitesimally small island (RH-83987)
    • Srf doesn’t unwrap until shrunken (RH-44746)
Enhancements:
  • FilletSrf: Support extending fillet across joined tangent surfaces (RH-4542)
UI Change:
  • Annotation: Hatch: Changed 'Boundary' checkbox to 'Select Boundary Region' in hatch creation dialog (RH-87584)
Bugs Fixed:
  • Display:
    • D3D: Vertex-Colored Mesh Issue (RH-87368)
    • Direct3D bleeds backface material bleeds through in parallel (RH-87502)
  • Markup: Markup command no return (RH-87420)
Rhino 9 WIP (9.0.25154) is now available for Windows and Mac
Bugs Fixed:
  • Annotation: Hatch: Overlay icons are blurry (RH-87422)
  • BooleanDifference: Boolean Difference makes polysurface with non-manifold edge (RH-37066)
  • Markup:
    • Causes restoring snapshots to always prompt ‘Unsaved model state’ (RH-87678)
    • May save to Snapshots panel (RH-87430)
  • Rendering: Cycles: Raytraced does not react to displacement changes while active (RH-62873)
  • Rendering: Materials: PBR Displacement "blows objects apart" (RH-62833)
  • Section Style: Current section style does not show after deletion (RH-87692)
  • SVG Editor: Does not open (RH-87672)
Enhancements:
  • Annotation: Hatch: Allows selecting hatch boundaries to create new hatches (RH-87596)
  • BooleanDifference: NURBS Boolean commands skip failed objects and continue for the rest (RH-77935)
  • Grasshopper: Supports new text frame styles in Rhino 9 (RH-87355)
  • Markup: Do not show markup objects in other viewports (RH-87611)
  • ScriptEditor: Upgraded Python Runtime (RH-81753)
  • UVEditor: Wish to be able to add to straightened edge constraint (RH-85992)
Regressions Fixed:
  • BooleanUnion: No Longer Merges (RH-87691)
SDK Enhancement:
  • SDK: RhinoCommon: Added ComputeMemoryEstimate to CommonObject (RH-87421)
Mac-Only Changes
Bugs Fixed:
  • Linetype: Need to purge twice on Mac (RH-86885)
  • Section Style:
    • Redo adds a style that never existed (RH-87283)
    • Incorrect section style name in use message (RH-87670)
  • WindowLayout: Toolbars all disappear (RH-75637)
Bugs Fixed:
  • RhinoUserInterfaceObject Animation doesn't work on windows (RH-86395)
  • Display: D3D: G2 Hides Last Point (RH-87630)
Rhino 9 WIP (9.0.25161) is now available for Windows and Mac
Bugs Fixed:
    • CMD+click duplicates patterns (RH-87800)
    • Hatch import broken in Hatch Command and Properties (RH-87791)
  • ChamferSrf: Change "Radius" in dialog to "Distance" (RH-87753)
  • Detail: DimCreaseAngle Access (RH-87737)
  • Displacement: Objects with PBR displacement clip in the view (RH-63314)
  • FilletSrf:
    • FilletSrf slider and range behavior (RH-87823)
    • Does not trim input surfaces (RH-87686)
    • Input surface incorrectly gets shrunk (RH-87776)
    • Fillet folds into itself (RH-87777)
  • Section Style: Cancel button on object section style dialog doesn't work (RH-87819)
  • UVEditor: ARAP result is not perfectly symmetrical (RH-80241)
Crashes Fixed:
  • ScriptEditor: Python scripts that open their own windows trigger crash (RH-80253)
Enhancements:
  • Morphing: UTD commands support morphing hatches (RH-87613)
Regressions Fixed:
  • FilletSrf: Extend option gives crumpled result (RH-87759)
Usability Problems Fixed:
  • ScriptEditor:
    • Language Error Messaging is Unhelpful (RH-85637)
    • CPython matplotlib needs a Rhino/Eto backend probably (affects pandas) (RH-74046)
Bugs Fixed:
  • Section Style: Revert to "By Layer" after a new custom style is selected (RH-87817)
Rhino 9 WIP (9.0.25175) is now available for Windows and Mac
Bugs Fixed:
  • Clipboard: PasteAt uses a different base point in layout space (RH-86194)
  • CurvatureAnalysis: Adjust Mesh button is not working (RH-87522)
  • Display:
    • Edge drawn differently in OpenGL Ghosted mode (RH-87961)
    • Monochrome settings not used or only seen on view manipulation (RH-87831)
    • Glass material appears pink in Rendered mode (RH-87852)
    • Display mode doesn’t change until view is manipulated (RH-87832)
  • Display: Direct3D: Sometimes SubDs are inside out (RH-87860)
  • Export: USD Export error, containing 2-byte characters (RH-86360)
  • File IO:
    • USD export blocks as instance definition instead of exploding them (RH-83782)
    • USD Export can fail when copying to network drive (RH-85017)
  • Fillet: Leaves input curve when it is trimmed to zero length (RH-87839)
  • FilletSrf:
    • Deletes entire brep (RH-87653)
    • Splits but doesn’t trim with Continue across faces (RH-87945)
    • Fails before shrinking surface (RH-80413)
    • Trimmed results do not join (RH-87913)
    • Extrusion is filleted on the wrong side (RH-86446)
    • Common edge is not found (RH-87981)
    • Edge remaining highlight when evaluated surface is deleted (RH-87845)
  • Grasshopper:
    • Pushed displacement amount doesn’t match (RH-86351)
    • Can’t get exr/hdr texture map into pushed basic environment (RH-87854)
  • Options:
    • Shade-highlight settings in Wireframe mode should be removed (RH-88080)
    • Control point style is wrong (RH-88060)
    • Control point size in viewports does not change (RH-88061)
    • Typo in Display Modes Properties (RH-87872)
    • Horrible Colors for Modified Settings (RH-87631)
  • ScriptEditor: Pip lists wrong package version after upgrade (RH-87767)
  • Section Style:
    • Document styles can’t be assigned to layers (RH-87864)
    • Assignment lost in object properties when model is reopened (RH-88039)
  • SelName: Dialog is not resizable (RH-88027)
  • SubD: Improve SubD surface rendered appearance (RH-87647)
  • Text:
    • Multi-lines change left and right mask margins (RH-88010)
    • Multi-lines change corner radius of rounded rectangle frame (RH-87293)
Enhancements:
  • Distance: Allow measuring distance between two selected points (RH-87389)
  • Grasshopper:
    • Update Page Layout class/component to surface all relevant properties (ie. page width, page height) (RH-87842)
    • Supports using block as custom annotation arrow (RH-81500)
  • Section Tools: ClippingDrawings command supports sectioning through curves (RH-80664)
Features Added:
  • Annotation: Hatch: Allow deformations of hatches (RH-51677)
  • Drag and Drop: Supports importing hatch pattern (.PAT) files (RH-29081)
Regressions Fixed:
  • Display: White Details are Black (RH-86976)
Mac-Only Changes
Bugs Fixed:
  • FilletSrf: Range options don't fit in default dialog size (RH-87922)
Enhancements:
  • FilletSrf: Simplify to revolves (RH-75374)
Bugs Fixed:
  • SelectionFilter: Setting selection filters does not release focus (RH-86699)
Features Added:
  • Annotation: Hatch: .Pat files can't be loaded via drag and drop, incorrect error message displayed (RH-64406)
Rhino 9 WIP (9.0.25182) is now available for Windows and Mac
Bugs Fixed:
  • Display: Direct3D: Screen does not refresh (RH-87984)
  • GeometricTolerance: Make GeoTol Cplane Aware (RH-88206)
  • Gumball: Double clicking UVN handles does not relocate gumball (RH-88185)
  • Markup: Markup to picture stuck (RH-88142)
  • Sketch: Eraser command (RH-83371)
Features Added:
  • GeometricTolerance: Geometric Tolerancing (RH-2256)
Bugs Fixed:
  • Display: Direct3D: Display: D3D: Gamma and AA = None (RH-88101)
  • Options: Display mode tree view nodes with non-default settings not always highlighted (RH-87960)
Rhino 9 WIP (9.0.25189) is now available for Windows and Mac
Bugs Fixed:
  • ChamferSrf: Continue across faces does not work when R1 != R2 (RH-87998)
  • Displacement: Object displacement settings don't work when PBR displacement is used (RH-88238)
  • GlobalEdgeContinuity: Number of edges is wrong (RH-88231)
  • Make2D: worksessions and selection (RH-69305)
  • Markup:
    • Sketch DynamicDraw doesn’t respect modified layer color/linetype (RH-88252)
    • Not clear which tool is active (RH-88193)
  • Options: Shading Effects setting does not stick nor can it be reset (RH-88223)
  • SelName: New dialog does not provide command-line feedback for selection count (RH-88286)
  • ShadeOptions: Display Options: All option sliders of Shadws are labeled the same: “Skylight shadow quality”. (RH-88273)
Enhancements:
  • Make2D: Simplifies output curves (RH-54485)
  • Markup:
    • Allows numeric input on sliders via double-click (RH-87725)
    • Use a better eraser appearance (RH-88253)
Mac-Only Changes
Bugs Fixed:
  • File IO: No Paste from RH8 into RH9 (RH-88278)
Bugs Fixed:
  • Analytics: All analysis panels are blank (RH-87637)
    • Object color bleeds onto Groundplane (RH-87955)
    • Ugly artifacts on viewport objects (RH-87953)
    • Pointcloud display does not update (RH-88234)
    • SSAO shadows don’t work with block objects (RH-88126)
  • Options: Removed Display Mode Pipeline Assignment (RH-88160)
Rhino 9 WIP (9.0.25196) is now available for Windows and Mac
Bugs Fixed:
    • Dragging lines are not drawn (RH-88342)
    • Does not display SubD Symmetry (RH-88247)
  • GeometricTolerance: Edit GeoTol Goes Away (RH-88208)
  • Make2D:
    • Inconsistent projection planes (RH-54657)
    • worksessions and selection (RH-69305)
  • Markup:
    • TestMarkupMode multiple docs (RH-88307)
    • TestMarkupMode, cplane isn’t restored correctly (RH-88343)
    • HUDs are not visible (RH-88350)
    • Rename TestMarkupMode to Markup (RH-88358)
    • Saving as picture wrong viewport (RH-88344)
    • Markup linetype applied after finishing markup (RH-88339)
    • Handle events in testmarkupmode (RH-88324)
    • Don’t draw UI objects from other docs (RH-88322)
    • Doubleclick anywhere triggers slider doubleclick (RH-88320)
    • Markup picture placement (RH-88340)
  • Squish: Mapping affects squish (RH-37281)
Enhancements:
  • Make2D: Perspective projection too small and not using CPlanes (RH-43490)
  • RhinoStart: Improved initial startup performance (RH-79171)
Features Added:
  • Annotation: Hatch: New HatchPattern command (RH-86998)
Regressions Fixed:
  • Squish: Texture can not be displayed normally (RH-67424)
Mac-Only Changes
Bugs Fixed:
  • Display Metal: Create GPU Page for Mac (RH-88135)
Bugs Fixed:
    • Lights don’t work when Skylight is ON (RH-88365)
    • Emissive and Transmissive material properties not being used (RH-88325)
Rhino 9 WIP (9.0.25210) is now available for Windows and Mac
Bugs Fixed:
    • Deleting pattern shows used by block when it no longer exists (RH-88611)
    • Deleted pattern returns (RH-88583)
    • Do not purge hatch patterns used in blocks (RH-88542)
    • Purged patterns come back when model is reopened (RH-88327)
  • Display: SubD Reflection Plane does not show across all materials (RH-88557)
  • Display: Direct3D: Point objects don't preview when scaling (RH-88463)
  • FilletSrf:
  • GeometricTolerance: Perpendicular Missing (RH-88410)
  • Markup:
    • First click in markup mode on HUD causes it to disappear (RH-88447)
    • First pick shows forbidden icon (RH-88526)
    • Don’t change CPlane (RH-88440)
    • Save model during markup mode locks the view (RH-88324)
    • HUD icons are missing randomly on desktops (RH-88501)
  • OSnap: Osnap: Right-clicking on Disable checkbox no longer toggles all object snaps (RH-88570)
  • OSnap:Dialog: OSnap Dialog: Buttons look disabled (RH-88125)
  • Patch: Cannot set angle tolerance below 0.1 (RH-88600)
  • ScriptEditor:
    • IronPython requires print with paranthesis!?! (RH-88282)
    • IronPython is missing for loop?!?! (RH-88283)
  • SelName: Set initial focus to search box in SelName commands… (RH-88303)
  • Squish: SquishBack does not maintain grouping correctly (RH-88450)
  • SVG Editor: Changing colors creates layers (RH-88459)
Enhancements:
  • Markup: Allows changing color and thickness of existing markup objects (RH-88454)
  • Rectangle: Added History support (RH-80611)
  • ScriptEditor:
    • Allow using custom package sources (RH-75515)
    • Adopted PEP723 in specifying in-script packages (RH-79829)
    • Support git+ protocol for pip install in python 3 (RH-87070)
    • Improved package referencing (RH-87834)
  • SelName: SelName dialog wishes (RH-82910)
  • Sketch: Added Smooth=Yes/No option (RH-85934)
Features Added:
  • SoftTransform: New UI with falloff color display (RH-55559)
  • ScriptEditor:
    • Support searching Grasshopper document folders for assemblies (RH-81129)
    • Support searching installed package folders for assemblies (RH-74573)
Mac-Only Changes
Bugs Fixed:
    • Purge > Add Defaults > Purge > Purge cause a crash on Mac (RH-88602)
    • New hatch pattern cannot be found on Mac (RH-88543)
  • BlockEdit: Window disappears on 2nd monitor (RH-88606)
  • Build Process: Discontinue support for Intel Macs (RH-88047)
Bugs Fixed:
    • Double sided PBR material produces weird results (RH-88532)
    • Select the wrong Intel GPU… (RH-88502)
    • GroundPlane Briefly Red (RH-88378)
  • SystemInfo: UpdatesAndStatistics plug-in listed as "not shipped with Rhino" (RH-88399)
Rhino 9 WIP (9.0.25217) is now available for Windows and Mac
Bugs Fixed:
  • CommandPrompt (Eto): Redundant History PopUp (RH-88411)
  • Displacement: Locks up when using multiple instances for a single object. (RH-88319)
  • Markup:
    • Picture frame tiny (RH-88635)
    • Enable snapshot save for markup mode (RH-88689)
    • Markup pictures are low resolution (RH-88627)
Enhancements:
  • Grasshopper: Added new Get Data context get component for Hops and GH Player (RH-78826)
SDK Enhancement:
  • Eto: Implement more RhinoEtoApp.MainWindow events and properties (RH-86166)
Bugs Fixed:
    • Technical mode shadows no longer work when AA set to None… (RH-88656)
    • Rendered mode and Ground plane are black in detail views (RH-88636)
Rhino 9 WIP (9.0.25224) is now available for Windows and Mac
Bugs Fixed:
  • Audit:
    • dmFile: Set a threshold for Geometry vs Attributes size (RH-88760)
    • dmFile: Disable right-click context menus if file is not open (RH-88754)
  • BlockEdit: Lights accessible in BlockEdit (RH-39420)
  • Display: viewport artifact in open gl (RH-88609)
  • FilletSrfCrv: Creates bad surface with radii that should work (RH-73356)
  • Rendering: Materials: Layer List Jumps to Top (RH-88493)
  • UVEditor: UV Editor: allow adding constraints even if some UV islands have Unwrap mode None (RH-86058)
Crashes Fixed:
  • Rendering: Texture Mapping: Crash editing Texture (RH-88692)
Rhino 9 WIP (9.0.25231) is now available for Windows and Mac
Bugs Fixed:
  • Explode: Pattern created by exploding a linked block is not added to document properties (RH-88610)
  • Markup:
    • List view markups (non-snapshot) (RH-88782)
    • Markups Panel, date created and created by (RH-88883)
  • Mouse & Trackpad: Middle mouse rotate doesn't work with advanced options (RH-88495)
Features Added:
  • Gumball: Object mode aligns arrow handles to control polygons of selected control point (RH-88089)
SDK Enhancement:
  • SDK: Added SectionStyle.ReadFromFile (RH-88742)
Bugs Fixed:
  • OSnap: RMB Osnap behavior doesn't work at start (RH-88581)
Rhino 9 WIP (9.0.25238) is now available for Windows and Mac
Bugs Fixed:
  • Annotation: Hatch: Do not list hatch patterns from linked blocks (RH-88793)
  • Audit:
    • dmFile: Parse Legacy Audit3dmFile output in File Auditor (RH-88761)
    • dmFile: Selection should work for top-level tables/rectangles (RH-88757)
  • BooleanUnion: Add ToNURBS options to boolean commands (RH-88221)
  • Display: monochrome silhouette fails in d3d (RH-88738)
  • Gumball: Gumball does not align to UVN when a ring of SubD vertices is selected (RH-88957)
  • SelLayer: Made scriptable command ignore prepick and show Pick option (RH-88818)
Features Added:
  • Gumball: Add Shift Option to Rotate (RH-88848)
  • Section Style: Allows importing section styles from 3dm files (RH-88734)
  • Section Tools:
    • ClippingDrawings: Project in place (RH-88803)
    • Add consistent drawing reference point (RH-89030)
Regressions Fixed:
  • Display: Technical Modes for Details is Busted (RH-86977)
  • Settings: Activating a Detail view does not update the Display Panel (RH-88922)
SDK Enhancement:
  • SDK: RhinoCommon: UndoRedoEventArgs missing document serial number (RH-89004)
Bugs Fixed:
  • Section Style: Import dialog may disappear and lock Rhino (RH-88913)
Rhino 9 WIP (9.0.25252) is now available for Windows and Mac
Bugs Fixed:
  • Annotation: Hatch: Incomplete import prompt in scriptable -HatchPattern command (RH-89018)
  • Audit: dmFile: Parse Legacy Audit3dmFile output in File Auditor (RH-88761)
  • BlockManager: Block instances highlight across layouts (RH-89107)
  • Clipboard: PasteAsBlock adds extra objects to new block definition (RH-86635)
  • Display:
    • Viewport starts stuttering after changing display options (RH-89123)
    • Custom materials do not render in V9 WIP (RH-88477)
    • Display Options Surface width usage setting (RH-88406)
    • Restore to defaults by section isn’t working (RH-88561)
    • Fixed visibility options in Technical mode (RH-88846)
  • Display: Direct3D: Materials panel missing thumbnails (RH-88930)
  • File IO: DWG: Attribute Text Justification Incorrectly Exports to DWG/DWF (RH-88129)
  • FilletSrf:
    • Moving Radius slider causes a crash (RH-88694)
    • Precision can’t be set higher than 4 (RH-79228)
  • GlobalEdgeContinuity: Labels are covered (RH-89187)
  • Gumball: Fails to edit surface points by object (RH-89067)
  • Libraries: Missing help button in Libraries panel (RH-88626)
  • Lights: Help button missing in Lights panel (RH-88620)
  • NamedPosition: : Icon needs to be changed to svg (RH-89181)
  • Patch: Pressing Esc at object selection prompt should cancel command (RH-88338)
  • PlanarSrf: Produces surfaces with inconsistent isocurves (RH-88953)
  • PushPull: Unable to determine selected region (RH-89068)
  • ScriptEditor:
    • Previous Files doesn’t show py2 scripts as IronPython (RH-88558)
    • Disable clear tests button when there are no rest results (RH-86154)
    • Disable tests tray buttons when running tests (RH-85962)
  • SetDisplayMode: Customized does not mark display mode as changed (RH-87982)
  • SplitDisjointMesh: Can’t be canceled by pressing ESC key (RH-89259)
  • SVG Editor: Icons are gone (RH-89026)
  • Trim: Trimming with extracted isocurves breaks surface edges (RH-88995)
  • Undo:
    • SelPrev and UndoSelection select wrong object after Invert (RH-89161)
    • Stops working after closing a floating viewport (RH-89089)
  • UVEditor: Allows adding constraints even if some UV islands have Unwrap mode None (RH-86058)
  • Zebra: store settings per canned mode (RH-88996)
Crashes Fixed:
  • Squish: TestSquishPhysicalStrain: Full Rhino crash in Release (RH-89184)
Enhancements:
  • BooleanDifference: BooleansDifference: Boolean commands packs SubD faces when converting SubDs to polysurfaces (RH-88952)
  • ClippingPlane: Allows double-click to toggle clipping state in active viewport (RH-89063)
  • GlobalEdgeContinuity: Shows max deviation dot (RH-89124)
  • Markup: Allows adding arrowhead to the end of a sketch or polyline (RH-88797)
  • ScriptEditor:
    • Improved testing output (RH-88475)
    • Support Shift+Selecting multiple tests to run (RH-87886)
    • Support querying test cases from test scripts (RH-85722)
    • Implement a way to Stop in Tests Panel (RH-85687)
    • Improve test results for Tests Panel (RH-85676)
    • Added filter to Tests Panel (RH-85677)
  • Trim: Added SelectCuttingObjects option when selecting objects to trim (RH-51183)
Features Added:
  • Markup:
    • Added a “Save as group” option (RH-88727)
    • Added a panel that lists existing markups (RH-88782)
Regressions Fixed:
  • Display: Box Display is not dynamic (RH-89093)
  • GlobalEdgeContinuity: Edges are visible when model is hidden (RH-89309)
  • SelName: Does not accept Escape when dialog not focused (RH-89298)
  • Toolbar: Sidebar has some issues (RH-89260)
UI Change:
  • BlockEdit: New BlockEdit icons needed (RH-89176)
  • Rendering: Moved render buttons to top in Rendering panel (RH-88623)
  • GlobalEdgeContinuity: Esc does not cancel the command (RH-89128)
  • ScriptEditor: Missing tooltip on editor tabs (RH-76429)
Mac-Only Changes
  • Preferences: Modified factory-default display modes are not painted blue (RH-55962)
Bugs Fixed:
  • Audit: dmFile: Access is denied (RH-89308)
  • Detail: Non rectangular details don’t work in vector printing (RH-88921)
  • Display: Direct3D: Shadow color not being used (RH-89115)
  • Settings: Customized lighting settings don’t work and don’t retain their values (RH-88578)
