A new bug has been discovered in Rhino 9 SR0 (2025-11-18, Rhino WIP 9.0.25322.06305) in Today's update,that causes all objects in the Rhino viewport to disappear , as if the file contained no geometry at all.
Can we get a little more information? What commands were you using? Was it all just drawing curves or were you creating other geometry types? Can you reproduce it? I saw a similar issue with meshes and subobject selection yesterday but it was patched before the WIP.
I have been creating tangent circles to the bunch of lines and, suddenly, everything is gone. Not a single curve, point or surface (there were plenty of them). I lost everything…. terrifying.
It wasn’t 3, but 30 minutes, but still…
On the side note: recovery from autosave was successful, but I’m moving back to V7.
@Piotr Do you have any recollection of the things you have been doing? Just drawing lines and circles, or is there more? If this happens again, pls run CommandHistory and post the results.
Did you experience this in the latest WIP? the result of _SystemInfo is highly appreciated.
Also: did things disappear when Rhino was idle or did it disappear when you were executing a command?
C:\Users\Piotr\AppData\Roaming\McNeel\Rhinoceros\Groupy.rhp “Groupy” 1.0.0.0
C:\Program Files\Common Files\McNeel\Rhinoceros\7.0\Plug-ins\Rhino 3DM File Version (aa091cb2-d8c0-4944-a17d-b66c80bec4ca)\7.0.7639.20582\RhinoFileVersion.rhp “Rhino 3DM File Version” 7.0.7639.20582
The bug still persists: if you edit a Box(PolySurface) usingSubObject(Control Point)selection and then perform an Undo, Rhino will hang and freeze.(Crash)
Point to move to <4.00>: .5
1 open polysurface added to selection.
Command: _Delete
Deleted 1 object.
Command: _Undo
Undoing Delete
Command: _Undo(this is where everything disappeared, or the first undo)
Undoing Move
Command: SW
Command: HideSwap
No objects were changed.
Command: SW
Command: HideSwap
Command: SW
Command: HideSwap
Command: _CommandHistory
Extension of the side edges failed with Type=Natural. Edge curves were extended linear
Command: _Undo (all gone)
Undoing ExtendSrf
Command: EX
Command: _Extend
Select boundary objects or enter extension length. Press Enter for dynamic extend ( Type=Natural Join=Merge )
Select boundary objects. Press Enter when done ( Type=Natural Join=Merge )
Select curve to extend ( Fence Type=Natural Join=Merge )
Select curve to extend. Press Enter when done ( Fence Type=Natural Join=Merge Undo )
