V-Ray 7.20 plugin fails to load in Rhino 9 WIP (9.0.25308)
Hi @Nikolay @brian,
After today’s Rhino 9 WIP update (9.0.25308), the V-Ray 7.20 plugin no longer loads.
Has there been a recent SDK change, or is this a bug introduced in the current WIP build?
For reference: Rhino 9 WIP — today’s build
The same plugin still loads and runs fine in Rhino 8 (stable).
It could be pointing to the wrong rhp
If you go to _PluginManager, then right click Vray and click Properties, what does it point to in File Name?
WIP builds are experimental, as you know, and I can repeat the issue here with the latest installer.
RH-90313 Vray for Rhino no longer loads
It is certainly not V-Ray. The PluginType() that is quoted is not overridden by V-Ray since we inherit from CRhinoRenderPlugIn which provides implementation of PluginType(). I guess it returns plugin_type::render_plugin
Anyway with the debugger I get some of the main functions called - PlugnInName(), etc.. but when I override PlugInType() Rhino never calls my implementation. So it is some subtle C++ quirk like ctor().call()instead of instance->call()
I’d like to report the similar issue is happening with the paneling tools plugin. exact same error pops-up
I have the same issue
I have to same problem loading V-Ray in the latest WIP.
Hi all -
A Rhino WIP version with a fix for this issue should be released in a few hours from now.
RH-90313 is fixed in Rhino WIP
Hi, I can confirm that Vray and other plugins like xnurbs, now load without problems in
Work In Progress
(9.0.25315.12305, 2025-11-11)
Thanks
