Rhino 9 WIP Toolbars duplicated
Hi All,
Today I tried to use my middle pop up toolbar and I got a message saying the the toolbar doesn’t exist… I imported it because I have a backup of this toolbar to use in other computers.
But it doesn’t work as expected, it only works if the toolbar is open somewhere in the screen, not if I add it to the top group of icons.
I decided to explore a little the location of the toolbars to see what may be happening, and this is what I have. Apparently Rhino is creating multiple backups of the toolbars.
Is there a way to save just one as a backup with all my scripts and custom buttons and reset the full toolbars interface to the defauls for the WIP?
That is a bug I created by accident, my apologies!
Youtrack : RH-96287 Toolbar backup creates a LOT of copies
RH-96287 is fixed in Rhino WIP
Joaquin -
We got the problem with multipl backups fixed. But I would like to take a look at the middle mouse button toolbar issue.
I expect that there is a different toolbar you are using that is not default.Popup?
When bringing in the RUI, does the toolbar that is assigned not exist? Or is it that the custom toolbar is not assigned to the middle mouse button?
Hi Scott, I haven’t experienced problems with the popup toolbar after the fixing.
And yes my popup was a custom toolbar I use it for different computers and import it.
During the time I had the problem, I had to import the toolbar each time I used rhino, because apparently the default toolbar didn’t have the one I needed.
