There is a problem with the display of toolbars in Rhino options.
The more you open the options window, the more the number of a group is duplicated.
jmv
jmv
Strange, this is a problem I’ve always had, since the first installation of Rhino 8. There is no particular step but here is how I proceed:
And here me sysinfo:
Rhino 8 SR10 2024-8-15 (Rhino 8, 8.10.24228.13001, Git hash:master @ f4c93f2b85de4dc69b50ed22f1b0d91445724d03)
License type: Commercial, build 2024-08-15
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.10
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce GTX 1080 Ti (NVidia) Memory: 11GB, Driver date: 3-1-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 551.76
Secondary graphics devices.
Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 6-1-2021 (M-D-Y).
- There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 3-1-2024
Driver Version: 31.0.15.5176
Z-Buffer depth: 24 bits
Total Video Memory: 11 GB
E:\Application\3d\Dev\ghgl\bin\net48\rhgl.rhp “rhgl” 7.8.0.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.10.24228.13001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.10.24228.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.10.24228.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.10.24228.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.10.24228.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.10.24228.13001
@Japhy
I’m doing some testing on my side and this only seems to happen on custom RUI files.
I’m often on the move and like to have my toolbars available no matter what workstation I’m at.
maybe it will be useful for you to have my RUI file:
JMV-Toolbar-8.rui (311.6 KB)
Thanks, poking at it. Is the .rui on a cloud drive?
I’m not sure I understand the question but I would say no.
I travel with a USB stick. Today I’m at home and the Rui file is saved on my hard drive.
Have you reproduced it or is it just my setup?
I have not.
Would be worth disabling 3rd party plugins, the only other variable that jumps out is Rhino version. I’m on the latest 8.12. I’ll roll back here in a bit and give it try in 8.10.24228.13001. I’ll also send you a link to the latest if that is an option.
Thanks @Japhy , I will try this!
jmv
still the same, I disabled the plugin and updated to version 8.12.
we’re not going to bother with that, once I have my toolbars configured this won’t be much of a problem.
jmc
I have the same issue for the Toolbars that we are preparing for our 100+ colleagues in the company I work in.
On top of the one you discuss above I have
We want to set up a clean and tidy user custom user interface for our colleagues, this is kind of impossible with all these bugs in Rhino 8.
After this we want to transfer the user interface automatically to the 100 or so machines, there is no mechanism for this in Rhino 8.
In the WIKI the last point is mentioned. MSH/Helvetosaur appears to tease a new procedure (see Transferring Personalized Settings [McNeel Wiki] ) , where it says:
Note on V8: The entire toolbar structure and arrangement has been completely re-written for V8. V8 no longer uses .rui files, the new format is .rws (Rhino Workspace). Rhino 8 can however import .rui files from V7 successfully in most cases. As soon as V8 is more or less finalized, I will update this section with detailed information on the V8 workspace structure procedures for transferring settings.
However, this did not materialize. We really look forward for a good solution herer as at the moment the workflow is quite buggy and, as far as I am concerned, broken.
It would be great to hear any news.
Hi Michael,
@CallumSykes or @Gijs can help with the big picture.
I’ll investigate these for existing bug reports. I may need steps to repeat / small example to replicate.
I am also looking for a solution to synchronize 2 Rhino installations (laptop and desktop), except obviously hardware related settings. I follow up the page Transferring Personalized Settings for updates.
With Grasshopper, is it possible to import a workspace at Rhino starting and export the workspace at Rhino closing ?
