New in Rhino WIP 2017-Aug-22
Rhino WIP 2017-Aug-22 is now available. Download Now.
New in this release:
FEATURE:
Bug:
  • Annotation: Alternate dimension bracket getting chopped off (RH-40554)
  • Annotation: Styles: Apply button on Annotation Style pages doesn’t activate (RH-40399)
  • Annotation: Text: Text string change not committed when text field dialog closes (RH-40416)
  • CommandHistory: Command history censored (RH-40907)
  • File IO: PLY should support point clouds (RH-40867)
  • Grasshopper: Bottlenecked geometry seems to have wrong normal data (RH-38781)
  • Localization:
    • Nesting the Length, Radius, and Distance commands doesn’t work in localized versions. (RH-40779)
    • Use Microsoft YaHei as the font for zh-cn toolbar, panel and options page (RH-37528)
  • Properties:
    • Materials page appears when you subobject select a curve (RH-40236)
    • Sub-object selection of a mesh face causes the Properties panel to be blank (RH-40799)
  • RDK:
    • Editing texture in floating panel broken (RH-40512)
    • Material texture gets resized in model when switching between Snapshots (RH-39492)
  • Rendering: Materials:
    • Bump texture in Rendered mode isn’t correct (RH-40773)
    • Drag and drop of a texture should create a Custom material not a Picture if Material is chosen (RH-40827)
  • Rendering: Texture Mapping: Custom texture mapping off (RH-39117)
  • Rhino Installer Engine:
    • Use compat to check whether a V5 plug-in can be installed for WIP/V6 (RH-40718)
  • ShadeSelected: Changes the Rendered mode view (RH-40504)
  • SubDFromMesh:
    • NURBS output option has missing subd patches near extraordinary vertices (RH-30499)
  • Templates: Update templates with new annotation style information (RH-40804)
  • ViewPropertiesPage: Custom viewport properties page doesn’t get scrollbar (RH-38727)
More Details.
Download Now and report any problems in this forum.
