Rhino 7 SR18 Release Candidate 1 for Windows and Mac (7.18.22102) is now available
To get it, subscribe to the Release Candidate update stream on Windows or on Mac
Bugs Fixed:
Color Picker: Central area intermittently was not what was actually used (RH-67326)
Curvature: Failed to mark max curvature on shallow curves (RH-68172)
Display: Empty dots slowed down performance (RH-68135)
File IO: FBX Export failed to set filetype properly unless it was the last argument in the list of options (RH-67758)
Geometry Core: ON_BezierSurface Loft made garbage (RH-67950)
Gumball: Did not work with viewport camera grips (RH-67784)
NamedView: Selecting a named view and did nothing else caused the document to be modified (RH-67642)
PointDeviation: Hair scale did not change (RH-68001)
RDK:
Materials panel showed different material count than RenderMaterials table (RH-67902)
SquishInfo: SquishInfo does not give any result, TestSquish does not show the debug logs for energy, Squish DebugOption Show3dMesh does not work (RH-66215)
Rhino 7 SR18 Release Candidate 2 for Windows and Mac (7.18.22109) is now available
Bugs Fixed:
Trim: trim with line option and extend lines set to yes fails on this file. (RH-67974)
Rhino 7 SR18 Release Candidate 3 for Windows and Mac (7.18.22116) is now available
Regressions Fixed:
Area: Area Command Failing on Rectangle (RH-68376)
Rhino 7 SR18 Release Candidate 4 for Windows and Mac (7.18.22123) is now available
Bugs Fixed:
Unlock: SubD edges could not be selected if they were ever locked (RH-68437)
Mac-Only Changes
Bugs Fixed:
Annotation: Text: Graphik font on Mac missing typefaces (RH-68433)
Rhino 7 SR19 Release Candidate 1 for Windows and Mac (7.19.22130) is now available
Bugs Fixed:
BlendSrf: Problem about interior shapes (RH-68315)
Rhino 7 SR19 Release Candidate 2 for Windows and Mac (7.19.22137) is now available
Rhino 7 SR19 Release Candidate 3 for Windows and Mac (7.19.22145) is now available
Bugs Fixed:
Trim: Non-trimmable lines selected by SelBrush or SelFence causing infinite loop (RH-68721)
Mac-Only Changes
Roll-back Xcode to 13.2.1 to fix major crash (RH-68800)
Rhino 7 SR20 Release Candidate 1 for Windows and Mac (7.20.22165) is now available
Bugs Fixed:
RhinoCommon samples requested by Maxwell developer (RH-68627)
DimArea: Reported a negative value in a specific case (RH-68956)
ExtractSubCrv: Reported too many messages in command-line history (RH-68919)
Gumball: Extrude handles did not show for sub-objects until Reflect was updated or removed (RH-68603)
GumballAlignment: Default did not update (RH-68735)
Lights: Dragging intensity spinner and releasing left mouse button on color box incorrectly popped up select color dialog (RH-68625)
NamedSelections: Adding selection sets did not trigger saving file prompt if no other changes were made in the model (RH-68727)
Picture: Displayed the old bitmap even after deleted (RH-68637)
Rhino 7 SR20 Release Candidate 2 for Windows and Mac (7.20.22178) is now available
Bugs Fixed:
Undo: Only one Undo was possible if Max undo memory was set to 4096 MB (RH-47940)
Rhino 7 SR20 Release Candidate 3 for Windows and Mac (7.20.22187) is now available
Tasks Completed:
RPC: The plug-in is discontinued since Rhino 7.20 (RH-69251)
Windows-Only Changes
Bugs Fixed:
LoadPlugin: Some plug-ins failed to initialize after installing the latest SRC (RH-69016)
Rhino 7 SR21 Release Candidate 1 for Windows and Mac (7.21.22193) is now available
Bugs Fixed:
File IO: Identical materials with different names in OBJ were imported as one material (RH-62963)
Rhino 7 SR23 Release Candidate 1 for Windows and Mac (7.23.22255) is now available
Bugs Fixed:
Layout: Layouts panel not updating when sorting layouts via code (RH-69837)
Rendering: Materials: Setting programmatic PBR property did not show in GUI (RH-69463)
TextField: Area function might return a negative value (RH-69998)
UVEditor: Showed old custom mapping mesh (RH-69757)
Enhancements:
SDK: Added C++ functions behind BrepEdgeList.RemoveNakedMicroEdges (RH-69805)
Rhino 7 SR23 Release Candidate 2 for Windows and Mac (7.23.22263) is now available
Regressions Fixed:
ViewCaptureToClipboard: ViewCapture: Materials become transparent (RH-70307)
Rhino 7 SR23 Release Candidate 3 for Windows and Mac (7.23.22275) is now available
Bugs Fixed:
Grasshopper: Contour component did not work properly (RH-70299)
Rhino 7 SR24 Release Candidate 2 for Windows and Mac (7.22.22290) is now available
Bugs Fixed:
Rendering: Cycles: Environment did not rotate in Raytraced mode (RH-70634)
Rhino 7 SR24 Release Candidate 4 for Windows and Mac (7.22.22301) is now available
