brian
(Brian Gillespie)
January 9, 2018, 10:57pm
1
Download Rhino 6 Release Candidate now!
We’re not adding any new features, nor are we making significant changes to the UI. We’re also done breaking the APIs, so plug-ins written for this Beta will work in the commercial release of Rhino 6.
New this week:
Bug Fixes:
Annotation: DimLinear: Wrong dims (RH-43325 )
Annotation: Hatch: Hatch Pattern preview (RH-43097 )
CommandHelp: Panel not displaying (RH-42721 )
Cycles:
Cycles needs performance control (RH-30807 )
Rhino Cycles / Raytraced mode is much slower then Blender Cycles (RH-41525 )
DevLoft: Devloft panel - is it working? (RH-43176 )
DevSrf: No icon for DevSrf Panel (RH-43174 )
File IO:
Creates 3dmbak when the option is disabled. (RH-43233 )
Obj import fails (RH-43164 )
When saving fails, Rhino doesn’t warn you (RH-43119 )
Help:
NoEcho link in command list broken (RH-43129 )
Typo in Advanced Rhino Render Settings (RH-43372 )
Localization:
A typo in en-us no commands.xml (RH-43293 )
AddNgonsToMesh/DeleteMeshNgons commands >prompt shows up in English (RH-43047 )
Command line option “Type” for DimArea and DimCurveLengthshows up in English (RH-43039 )
Decal panel > drop down list shows English (RH-43045 )
Dim command > prompt “Dimension line location” shows up in English (RH-43038 )
Displacement Object Properties panel - “Displacement” section name overlaps with separator (RH-42758 )
DocumentProperties > “Plug-ins page” shows up in English (RH-43284 )
DocumentProperties > Plug-in page > “details” and “Yes” show up in English (RH-43042 )
Emap dialog needs some adjustment. (RH-42723 )
Environment panel > menu > Set as 360° Backdrop Environment shows up in English (RH-42991 )
License info - Resizing needed (RH-43224 )
Lots of buttons on Object properties tab show up in English (RH-43035 )
MeshRepair panel shows English (RH-43295 )
Panel > Gear icon > panes list > “BoxEdit” and “UVN Move” show up in English (RH-42999 )
Some drop down list items in import/export options dialog boxes show up in English (RH-43172 )
Sun panel > City names are duplicated in localized versions (RH-43079 )
Tutorials command > dialog shows up in English (RH-43046 )
Two strings on DevLoft panel show up in English (RH-43002 )
Unlocalized dialog option in ViewCaptureToClipboard command (RH-43266 )
NetworkSrf: NetworkSrf does not work with more than 100 curves. (RH-43274 )
No Subsystem: Help > Support mail in French redirects to tech.fr@mcneel.com (RH-43221 )
Rendering: Rendered error with Mesh objects (RH-43204 )
Rendering: Materials:
Material previews are black on French Rhino (RH-43212 )
Texture panel > Single Color Texture > Super-sample check box and Use object color check box overlaps (RH-43291 )
SDK: RhinoCommon: SetLocalizationLocaleID causing linker errors with Rhino3dmIO.iOS (RH-43253 )
Sweep2: Rebuild fails with four points (RH-43145 )
Toolbar:
ViewCaptureToFile: Colors wrong (RH-43289 )
Download Now and report any problems in this forum.
Marc
(Marc Gibeault)
January 10, 2018, 3:12pm
4
Sad that this problem, Is this kind of planar mapping possible? , hasn’t been touched…
It means that for these projects I’ll have to use something else than Rhino…
D-W
(Przemysław Doliwa)
January 10, 2018, 3:20pm
5
@pascal Is Testmoocow on its place ???
Alan_Farkas
(Alan Farkas (he/him))
January 10, 2018, 5:32pm
7
after install, do I just use the same Rhino Shortcut Scheme icon I’ve been using for Rhino 6 Beta? (i.e. is this just another updated Rhino Beta?)
Thx
JayR
January 10, 2018, 6:22pm
8
Nearly 50% of the button mouseover text is missing. Maybe only in german translation?
John_Brock
(John Brock)
January 10, 2018, 6:25pm
9
Correct. There is no cosmetic change to the beta.
wim
(Wim Dekeyser)
January 10, 2018, 6:52pm
10
That one is still on the slate for 6.1 - so, all hope is not lost
See RH-37073
It’s one of 2 things that I miss from Rhino 5. (The other being panels that remember their positions…).
mikolaj
(Mikolaj Jarski)
January 10, 2018, 7:09pm
11
Not only - tooltips are missing from all language versions.
Youtrack issue: RH-43337
D-W
(Przemysław Doliwa)
January 10, 2018, 7:33pm
12
foreigner
(foreigner)
January 10, 2018, 8:57pm
13
Viewport (Rendered) after use “SubDFromMesh” and delete the mesh object was black and freezing and the other viewports
stevebaer
(Steve Baer)
January 10, 2018, 9:07pm
14
This is not slated for V6
SubD display in V6 still needs a lot of work and won’t be completed for the initial release of 6.0. We kept SubDFromMesh around because users needed it, but it is a “Test” command in Rhino 6.
We are investigating this issue this week.
brian
(Brian Gillespie)
January 10, 2018, 9:30pm
16
Marc:
Sad that this problem, Is this kind of planar mapping possible?, hasn’t been touched…
Looks like that bug never got logged. I just logged it as https://mcneel.myjetbrains.com/youtrack/issue/RH-43457
This bug will be fixed in the first service release. An SR1 release candidate will go out almost immediately after 6.0 is released.
D-W:
This is also missing ?
There are 7,549 open issues on our bug tracker logged toward Rhino for Windows. Almost none of them will be fixed before we ship Rhino 6.
D-W
(Przemysław Doliwa)
January 10, 2018, 10:03pm
17
@stevebaer @brian Sure i understand You have lots of work and i really appreciate that I just thought it wouldn’t be that hard to fix cause afaik was last piece of achieving full dark ui experience i know there are more crucial things but this one would give few smiles on faces around
brian
(Brian Gillespie)
January 10, 2018, 10:21pm
18
That might be true. There are probably another 500 issues on the list like that. It’s not about hard or easy, it’s about minimizing the changes we make as we try to stabilize Rhino for release.
coby
January 11, 2018, 12:48am
19
This is a small thing but the ‘between’ option is missing on the one-shot Osnaps. Am I missing something here?
SamPage
January 11, 2018, 12:55am
20
It should show when holding Shift, rather than Ctrl while hovering over the OSnap window.
Charles
January 11, 2018, 8:20am
21
Coby
Between is now with Shift and not Ctrl.
