RESTful.Gdal error with Heron
Hello @Brian_Washburn
I haven’t used Heron for a while and today I updated to the latest version of Heron using the package manager. First I deleted the old version folder from grasshopper components folder. Then, I installed Heron with package manager. But I’m getting this error on most components:
1. Solution exception:O inicializador de tipo para 'RESTful.GdalConfiguration' accionou uma excepção. which roughly translates to "The type initializer for ‘RESTful.GdalConfiguration’ added an exception’
I also had Elk installed which has its own GDAL dll. So I tried to delete the folder from the Grasshopper components folder. Yet, the error persists. Any ideas?
Best regards,
Hi @Filipe_Brandao ,
Can you try following the steps from the post below and let me know if that fixes the issue?
-Brian
It worked after restarting Rhino. Thanks!
Filipe
Hi @Brian_Washburn I tried the suggested Solver solution but I continue to receive the same error.
