I saw there was another topic about this particular issue but after many attempts to uninstall, reinstall, and revert to an older version I have been unsuccessful. I am using 0.4.1 installed from package manager.
Hi @dale ,
Yes, I’m the developer of Heron. Heron is built on GDAL (c# bindings pulled in from nuget) which generates a folder of dependencies required for it to run and which are packaged with Heron releases as a subfolder. It seems when GDAL can’t find the subfolder, GDAL throws the type initializer error.
A GdalConfiguration.cs comes with the GDAL bindings telling GDAL where to look for the dependencies. I had been using Assembly.Location to get the executing directory which seems to work in many cases, but apparently not all. It had never been an issue until I started releasing through the package manager. The code below is the latest attempt to fix the issue, but has not yet been released, so the version 0.4.1 that @Graham_Felton is using has the commented out parts active.
As is likely evidenced in my code, I’m wouldn’t call myself a programmer, just a hack, so there could easily be other reasons the error is thrown. I appreciate any help you can provide.
