Import Vector error
Hi @Dongyeop_Lee ,
I have seen this happen when installing Heron through the package manager, which is the preferred method (related Heron Github issue). Basically, Heron is looking for GDAL libraries and can’t find them when they are installed in the packages folder. The work-around for this issue has been the following: in Grasshopper Settings>Solver>Plug-in Loading, scroll down to Heron and click the little puzzle piece icon so that you see the disk.
I have found a possible fix here which I will try implementing in the next release:
-Brian
