Render differences between viewport and renders
why is there such a difference between my viewport render :
and the render created by rhino :
and is there anyway to solve this problem…
The first one is Rendered mode, correct? Not Raytraced? In that case: Rhino Render uses the same engine as Raytraced, you see indirect lighting bounces.
You can turn down the amount of diffuse bounces in the advanced settings section in the Rendering panel, set it to 2 or 1, that will give you darker shadows since there will be fewer light bounces.
You could also try View > Capture to File and even save the transparent background in the PNG-file.
thank you very much, I will try it soon !
