Different render result
Why is so different the result of Raytraced and Rhino render with the same settings?
Vittorio
RAYTRACED
Rhino Render
I’m suspecting you use custom materials here. If you do you should know they are still being improved.
Could you share the file with me so I can give better info on why they look different?
/Nathan
Hi Natham
I send to you a file.
Vittorio
Hi @vittorio, did you send it to nathan@mcneel.com ?
Yes
Vittorio
Your file didn’t have all texture/environment files embedded, but that’s ok, I could test without as well.
Clearly Rhino Render does GI differently from Raytraced. It looks like Rhino Render doesn’t properly use i.e. the solid background color if that is set as back ground. This alone already causes quite big differences when skylighting is enabled.
