I was hoping for a bit of advice on rendering. I have a point light shining through some features, and i want to render the shadows nicely. However I cannot see the point light shining in the final render? Can anyone explain why this is, since I can see it in the ray traced view (which should be the same as the final render)?
Rhino Render in Rhino 6 uses a different rendering engine then Raytraced. If you want to get the same in Rhino 7 Raytraced and Rhino Render use the same engine.
