In V6 when I print this hatch nothing get printed. Either to PDF or to a printer. Any thoughts? Hatch Problem.3dm.pdf (8.3 KB)
Hatch Problem.3dm (55.6 KB)
Hi djnelson,
The hatch is apparently composed of points. If I print as raster, I do see them , however printed as vector they are not printed. I guess @stevebaer knows who -if not himself- can help with this printing issue.
Something else I notice is that I cannot explode the Hatch @pascal : this might be a bug to track.
-Willem
Thanks. Yeah your right raster does work and vector doesn’t. I forgot to check that. For what it’s worth it’s a pattern that was imported from Autocad.
Maybe you can provide the original ACAD file ( or a similar one) for the developers to scrutinize and test with.
-Willem
No problem. Here is a dwg file and the .pat file.
AR-SAND.zip (36.1 KB)
Yep this was reported by someone else a couple of days ago -
and buggified:
https://mcneel.myjetbrains.com/youtrack/issue/RH-45091
–Mitch
