Rhino 8 (Win) - Hatches not printing properly
Hello! I would be grateful if someone could help us with a frustrating issue with Rhino 8 for Windows.
We have just updated to Rhino 8 from Rhino 7 and we are unable to print hatches AR-SAND and AR-CONC properly.
Hatch test.3dm (71.7 KB)
Hatch Test.pdf (3.3 KB)
The “dots” from each hatch pattern appear on the viewport but do not print. We use Rhino PDF / vector output. The hatch pattern appears OK when using raster output, but unfortunately we cannot use raster output due to file sizes.
Attached is the rhino file and printed PDF file
Any help would be most appreciated. Thank you so much in advance!
Hi Diego, I see this, thanks.
RH-79860 Print misses single pixel hatch
I’m pushing a fix for this right now. This fix will be available in the next 8.4 release candidate that should be available on Tuesday. If you need a build of Rhino with this fix before Tuesday, let us know and we’ll send you a link.
Thanks,
-Steve
RH-79860 is fixed in Rhino 8 Service Release 4 Release Candidate
Thank you so much to all of you for your prompt help! We’ve downloaded the latest service release and the issue is now sorted.
All the best
Diego
