Dear Rhino community,
i have a big problem when i print vector PDFs in Rhino 6.
When i choose in the print setup vector output, all lineweights are the same.
When i choose raster output all lineweights will print in the correct width.
Moreover using the Rhino 6 file in Rhino 5 all lineweights print correctly.
Is this a bug in Rhino 6 or a problem of my system?
Hello Pascal,
l upload a picture of the line widths and linetyps settings of rhino 5 and 6. Also I updated all drivers of my computer and used different pdf-printers like bullzip, cute pdf, adobe pdf, rhino pdf etc. In Rhino 6 I get all the time the same line width problem.
My system is a alienware 17 a4 including a nvidia 1080gtx graphic card and with a 4K monitor.
Until now I am very happy with Rhino 6 except of this vector printing problem…
Hi Maximilian - can you please try opening Options > PlugIns page and disable the various non-default plug-in (VisualArq, Vray, Lumion) then restart Rhino and see if that has any effect? You might also look for a driver update notification in the Notifications panel, double-click and go through the process of updating (both NVidia and Intel) drivers. Let us know if either of those does anything.
Hey Pascal, i did everthing you write but nothing changed.
Updating Nvidia, Intel drivers and disable the different plugins don’t slove the problem…
I also made a Make2D and try the diffrent rhino viewport display… same story…
An idea was to scale the line width up in the print setup ( Linetypes and Line Width). But there is a problem because the lineweight I scaled manually is not right to the scale i set in the printer setup.
Can you reproduce the problem if you create a new file in Rhino 6?
When I create a new Rhino 6 file there is still the same problem with the lineweights in vector print. I only get proper lineweights when I safe my Rhino 6 file as Rhino 5 and print in Rhino 5.
Or does it only happen when opening a Rhino 5 file?
No, I create and work on my projects in Rhino 6 and also safe them as Rhino 6 files. Only for printing I go the detour with Rhino 5 to get proper lineweigts.
I tried reproducing this by opening your file in Rhino 6, no luck. I also tried on a high-DPI display - no luck.
When you get the same results like me… is it possible that this is a bug in Rhino 6 which every Rhino 6 user have?
I have the same problem. The layer print width doesn´t do anything but I work around it by going through properties panel with every individual curve and there set their print width and it works with the printer too.
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.0
Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 11-3-2021 (M-D-Y).
Primary OpenGL: NVIDIA GeForce RTX 3060 Laptop GPU (NVidia) Memory: 6GB, Driver date: 6-28-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 556.13
> Integrated accelerated graphics device with 1 adapter port(s)
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-28-2024
Driver Version: 32.0.15.5613
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
c:\Program Files\Solemma\ClimateStudio\bin\ClimateStudioRhino8.rhp “ClimateStudioRhino8” 2.0.8851.17966
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V8\VRayForRhino.rhp “V-Ray for Rhino”
