Hello, I have tried printing with multiple PDF creators and none of these work.
CutePDF
AdobePDF
Bullzip PDF
I have tried printing from view port and form layout. No matter what lines weight are always the same.
I also opened each pdf in Ai, they all have 0.042mm lines.
I have carefully set lines weight for each layer, checked the objects where in the correct layer. Even turned on PrintDisply, and I can see the line weight difference in both viewports and layout.
No idea what Im doing wrong.
Thanks in advance.
Shynn.
This seems strange, I have no trouble with lineweights out of Rhino 5 on windows. Your file download link isn’t working, so I can’t check your file - maybe try re-uploading the rhino file? I can consistently export to .ai with lineweights preserved, though it does a conversion from mm (in rhino) to pts (in illustrator). When I print to Adobe PDF my lineweights show up just fine.
Hi ShynnSup - in the Print dialog, scroll down to the “Linetypes and Line Width” section and scale the line width up some - I don’t know how much you’ll need.
Hey Pascal, that helps, but how do I make it so that they match size I choose for them before printing. The scale would be 1:1, but that results in not the correct scale again… As they all look the same when they are not…
I’m using Rhino 6. I lose line weight and transparency when I print to vector PDF. It looks correct in raster but I cant use raster in this instance. I can’t find a solution.
Michael, I am having the same problem as you- I can print to raster and have lineweights just fine, but vector loses all line weights, did you ever find a solution?
