Polyline on a surface
I am trying to create one single curve that covers all my surface that has holes in the middle. How can I do that? I started to divide the curve in points and interpolate them, but it goes over the holes. Something like in the image where I can varying the distance between the line.
thanks
To achieve a continuous curve as the one you drew you could try reversing the order of every other point “column”. However, to account for the holes you could find a way to split the base surface depending on the position of the holes (for example, using a polyline that goes through the centers of the holes).
It could be quite simple or hard depending of what you want.
Here an exemple
Mesh your surface (with MeshMachineStatic for example)
Make a path/road with no loop,
use Maze
http://www.grasshopper3d.com/forum/topics/maze-from-mesh
or Shortest walk
or Ivy
Then offset this path with Clipper offset
or thicken the network and get naked edges
http://www.grasshopper3d.com/forum/topics/thicken-a-network-of-lines-with-specified-half-section
Smooth polyline if needed
That’s all !
Using Dual Mesh (from Ngon) and Shortest Walk it gives that
