Grasshopper - Arrayed Curves on surface at specified distance parallel to existing line
Hi All,
This is my first post. See attached image for reference. I am trying to array curves on a surface similar to a tween curves action but in grasshopper while being able to specify distance in between and run parallel to an existing curve on the surface.
Additionally, I would like to turn the curves over two or more surfaces to be continuous as well as an additional step. The first step is more important though. Thank you!
Welcom to the forum.
Please see this (click the link and read the whole post):
In particular, pay attention to Item #3:
3. Attach minimal versions of all the relevant files
If you have a gh file you have a question about, attach it to the post. Do not expect that people will recreate a file based on a screen-shot because that’s a lot of pointless work. It’s also a good idea to remove everything non-essential from a gh file.
If you attach a file, you are likely to get a response with that file updated to include the solution to your question.
As far as your current question, perhaps the Contour component?
Or perhaps you could extract edges, divide, and create lines.
-Kevin
