Hello Guys
Please tell me how you can build a central line between closed curves and project it onto the surface. The lines lie on the development of this surface.
Hello Guys
maybe this will help you for finding the central line
You can try this way:
1- Create a surface from the curves, apply black material and print it as image.
2- Use the result image with the script of @laurent_delrieu to create medial axis
image_thinner_LEGACY_m.gh (10.4 KB)
Here a version of the “thinning” script that doesn’t need an image. It is quite fast due to the fact that I use mesh intersection to know if points are inside or outside curves.
The input of the thinning algorithm is a list of boolean (equivalent to black and white). You need to put the number of pixels in X. The number of pixel in Y is calculated using the size ratio.
This gives that on the plane
I use Map To Surface from Parakeet
image_thinner_LEGACY_boolAsEntry.gh (2.0 MB)
But as you certainly use Voronoi to draw the initial shapes why not using Voronoi cells
Thank you more than what you need !!!
Rays of gratitude!!
I just always thought how to return such a surface to the form after processing on a plane
