I am trying to “trace” a curve surface with a continuous line in both directions (vertically and horizontally). The drawing shows my goals: trace with one line a surface which is curve and the starting point and the end point is the same.
For now I manage to do it with two different lines (one for each directions), but the points are inside the surface and not in the boundary (first problem), they are two different lines instead of one (second problem), the starting point and the end point should be the same. I subdivide the curve in point in order to get the point on the surface to connects and to be able to change the density.
Do you know how to do that?
thanks
path surface curve.gh (12.3 KB)
