I’m having an issue creating plan views that show anything below the cut plane, even in the simplest of models. I’ve tried changing level offsets, visibilities, changing the plan view’s view depth, tolerance factors, etc…
Hi @ethanmiller Does that happen with Rhino geometry only or with VisualARQ objects too? Can you send me that model to visualarq@asuni.com so I can check it out?
Thanks,
Hi @ethanmiller got the file thanks! I can see all goemetry in the Plan View (except some missing block definitions), but I suspect you can’t due to an error with the last version update (2.0.14). We will upload a new release (2.0.15) later on today , so once it is available, open your model with it and update the plan view (vaUpdate). Then let me know if the problem persists:
