I want to create a simple plan only use rhino surface, but I can’t see anything when I create a plan view use VA, I want to know some surface which not been cut by the cut plane can be show in the plan view? I try to create slab from surface but the plan is same…
Maybe this is a little bug, when I update to the latest version the plan view can be show right.
Hi @11181, There was a bug in previous versions that was making some objects do not appear in plan views. So updating to the last release (2.0.15) this problem will dissappear. You just need to udpate your plan views (select them and run the vaUpdate command) when you open that file.
