OK we are on to this, we are aware of the full extent of the problem 6000 images in total which were from 2015 and older were impacted.
There is a long story here but back in 2015 we had a different file upload naming scheme and we did not migrate mcneel to the new scheme. We are doing a full analysis here to see if there is anything we can do to recover the images. @stevebaer any chance you have an old backup hanging around somewhere?
Regarding @Holoās issue, this is different and somewhat complex. What happened here I think is.
You uploaded the image on another post (or draft)
Then you right clicked on the image, copied the URL and put it in the holomark2 post.
This leads to a somewhat complex and not great situation, which I will make sure we fix in core. Since the URL is to a smaller and optimized version of the original our internal processes that map āuploadsā to āpostsā did not pick up that this post contained the upload. Later your draft disappeared or original post with the image got deleted, the reference between post and image was lost and it was removed.
My question is. Could you add some kind of iframe support and we share images from our own clouds?
Probably 50% of the code examples Iāve posted were images. I guess that was a wrong. Iāll try to use the code tags from now on as much as possible.
We will make core more resilient so you do not need to remember that. If it easy for you to add a new image there please do so, its probably a 20-30 minute job for us to dig it up from backups, if we even have it (we may cause its not that old)
I have a super old discourse from version 0.9.8.1 that is sitting dormant on ec2. I might be able to revive it, but Iām not sure how much weāll get out of that.
