[link to the relevant thread ]
Yesterday I was helped to solve a problem. The problem was happily solved.
But during that process, I was asked to do a Factory Rest [which is obviously commonly needed to find problems.
As per the instructions I saved the Window Layout file, and the support Zip file.
Upon restoring my custom setup. I seems to have lost quite a few things, some I don’t mind because they are easy to redo… [colors, and all sort of options settings that were lost]
But I also lost all the custom keyboard shortcuts. and this is a bit of a biggish problem as it will take a few good hours to manually redo all of these [unless hopefully someone can please show me a way to restore the keyboard SC from the zip support file…?]
So apart from the need for help here, I wish to ask the Mcneel support and devs, to please fix these gaps in the saved customization !
And until this is done, and everything, Everything is saved in one file.
Kindly create a detailed instructions that cover all the parts that user can customize.
Please consider each user on every reset request, as someone who did heavy customization [even if he/ she did none…].
Consider composing a comprehensive instructions and simply attach that to any reset request.
And please let us know what is not [yet covered/ restorable]. are there work around? and if not, we need to know so we can make a choice regarding following the reset request.
Thanks a lot
and apology for the frustrated tone.
With best regards
akash
