Rhino 8 randomly undoes all my settings every few days
Dear Rhino community,
Something strange and frustrating has been happening. Every so often, my Rhino 8 will lose all my custom settings: appearances, aliases, keyboard, mouse, custom display modes will all be reset. It will happen in the middle of work sessions, switching between applications, and generally in subtle moments without my understanding why. I thought it was when I would open DWG’s in Rhino 8 or when I would open Rhino 7 files from colleagues that would trigger the re-set but this doesn’t seem to be the cause. It just happened again and I am at a loss. I wonder if anyone has any insight.
The only hint is that each time it resets, I am left with three Shaded views in my Display Modes menu (see screenshot). Some of my custom display modes are copies of the default Shaded view so I don’t know if that might have something to do with it.
Any insight is appreciated. I tried the method of having my settings copied in the AppData/Roaming/… /settings also without success.
Hi Lucas -
I’m not sure what that method is exactly but you can OptionsExport to get most things saved to a text file and OptionsImport to get them back if things go South. But next time this happens, please use Reset and click the button to save the settings for support - send the zip file to tech@mcneel.com with a link back to this topic in your comments.
Meantime, plase run SystemInfo in Rhino and copy/paste the results here.
Thank you, Pascal
OptionsExport and OptionsImport will already help a great deal. Didn’t know about that. Previously I was following the method outlined in this post: Rhino settings backup in RH8
SystemInfo results:
Rhino 8 SR4 2024-2-13 (Rhino 8, 8.4.24044.15001, Git hash:master @ 5d3f86ffffae3c2ed84d21147c008b3907a40a2e)
License type: Commercial, build 2024-02-13
License details: Cloud Zoo
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.16
Primary display and OpenGL: NVIDIA T1200 Laptop GPU (NVidia) Memory: 4GB, Driver date: 10-13-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 529.19
Primary OpenGL: NVIDIA T1200 Laptop GPU (NVidia) Memory: 4GB, Driver date: 10-13-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 529.19
Secondary graphics devices.
Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 7-11-2023 (M-D-Y).
- There are no monitors attached to this device. Laptop lid is probably closed
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 10-13-2023
Driver Version: 31.0.15.2919
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V8\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.4.24044.15001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\RhinoLabsTools.rhp “Rhino Labs Tools”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.4.24044.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.4.24044.15001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.4.24044.15001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.4.24044.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.4.24044.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.4.24044.15001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.4.24044.15001
C:\Program Files\Rhino 8\Plug-ins\NamedPositions.rhp “Named Position”
Hi Lucas - it would be useful to know if this happens without VRay being loaded - if you can work without it for a while, disable it in Options > Plug-ins page and then close and restart Rhino. Can you work for a while without the bad thing happening, when it probably would have happened by now in the past?
Hi Pascal,
The options reset happens at very irregular intervals. Sometimes two days in a row, sometimes it will be ok for a couple weeks without the reset. I think it might be hard to do a controlled troubleshooting disabling Vray since I often need to use Vray several times during a given week.
I will try it and pay attention when I turn Vray back on
Luca
The issue just occurred again - for the first time since this original posting eight days ago.
OptionsImport saved me the headache of redoing my settings so I am grateful for that tip. But the issue of losing my settings remains a mystery. I cannot trace it directly to Vray since I have been using vray fairly often throughout these past eight days.
I sent the zip file of the settings after the Reset command to the tech email.
Hi Luca - can you please, when you get things sorted again, export the good settings in th same way?
It happens to me every time I close and reopen Rhino. So annoying!! Have been using the trial version for a couple of weeks now.
Our office has been having the same issue with display styles, aliases, settings etc all randomly resetting. Using OptionsExport/Import is helping to speed up the reset but it’s not ideal. Let me know what I can do to help diagnose the issue. Thanks
Seemingly I also share some of these issues where I notice that my viewport colors keeps reseting after reboots. I am running Rhino 8 licensed on Macbook Pro 2019. Let me know if I could supply any further info for the debug team to diagnose the issue.
Thank you and best regards!
Hej Josef -
Does that mean that you can shut down Rhino and then start Rhino again and the viewport colors will be as they were, but when you reboot the machine and start Rhino, the viewport colors have changed?
Please run the Rhino SystemInfo command and copy-paste the result here.
Hi Wim,
Apologies for my delayed reply, thank you for your attention to the issue. It happened sometimes after the machine was rebooted or shut down. Have not had any problems with just restarting Rhino and having viewports colors change.
However I have not noticed it happening anymore so maybe its fixed via macOS or Rhino update but also been off for Holidays so have not been that active.
I will return if I notice it again, nevertheless here is my SystemInfo:
Rhino 8 SR14 2024-12-10 (Rhino 8, 8.14.24345.15002, Git hash:master @ cdb74b46090a23fe242c51b288886f76467a741b)
License type: Commercial, build 2024-12-10
Apple macOS Version 15.1.1 (Build 24B91) (Physical RAM: 32GB)
Mac Model Identifier: MacBookPro16,1
Language: en-SE (MacOS default)
.NET 7.0.0
Metal GPU Family Apple 0
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
Intel UHD Graphics 630 (1536 MB)
AMD Radeon Pro 5300M (4 GB)
Color LCD (1792 x 1120 @ 59.00Hz)
DELL S2722DC (2560 x 1440 @ 59.00Hz)
GPU Vendor: AMD
USB devices
Generic: USB3.2 Hub
Lenovo: Lenovo Traditional USB Keyboard
Realtek: HID Device
Apple: composite_device
Apple Inc.: Touch Bar Backlight
Apple Inc.: Touch Bar Display
Apple Inc.: Apple Internal Keyboard / Trackpad
Apple: Headset
Apple Inc.: Ambient Light Sensor
Apple Inc.: FaceTime HD Camera (Built-in)
Apple Inc.: Apple T2 Controller
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/swift/libswift_Builtin_float.dylib
/usr/lib/swift/libswift_errno.dylib
/usr/lib/swift/libswift_math.dylib
/usr/lib/swift/libswift_signal.dylib
/usr/lib/swift/libswift_stdio.dylib
/usr/lib/swift/libswift_time.dylib
/usr/lib/swift/libswiftsys_time.dylib
/usr/lib/swift/libswiftunistd.dylib
/usr/lib/swift/libswiftDistributed.dylib
/usr/lib/swift/libswiftObservation.dylib
/usr/lib/swift/libswiftMLCompute.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/usd/libusd_ms.dylib
/usr/lib/swift/libswiftSpatial.dylib
/usr/lib/swift/libswiftNaturalLanguage.dylib
/usr/lib/swift/libswiftSynchronization.dylib
/usr/lib/swift/libswiftGameplayKit.dylib
/usr/lib/swift/libswiftSpriteKit.dylib
/usr/lib/swift/libswiftWebKit.dylib
/usr/lib/swift/libswiftGLKit.dylib
/usr/lib/swift/libswiftMetalKit.dylib
/usr/lib/swift/libswiftModelIO.dylib
/usr/lib/swift/libswiftSceneKit.dylib
/usr/lib/swift/libswiftVideoToolbox.dylib
/usr/lib/swift/libswiftMapKit.dylib
/Applications/Rhino 8.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 8.14.24345.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 8.14.24345.15002
/Applications/Rhino 8.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 8.14.24345.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 8.14.24345.15002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 8.14.24345.15002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 8.14.24345.15002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 8.14.24345.15002
/Applications/Rhino 8.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 8.14.24345.1002
/Applications/Rhino 8.app/Contents/PlugIns/SectionTools.rhp “SectionTools” 8.14.24345.1002
/Applications/Rhino 8.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 8.14.24345.1002
/Applications/Rhino 8.app/Contents/PlugIns/Displacement.rhp “Displacement” 8.14.24345.1002
/Applications/Rhino 8.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 8.14.24345.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 8.14.24345.15002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 8.14.24345.15002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp “RhinoCodePlugin” 8.14.24345.15002
Something similar has been happening to me since I started using Rhino V8 for Mac about a year ago. For me, the thing I always notice is the two particular custom color settings I use which are the “Selected objects” setting (Appearance>ObjectDisplay) and “Layout” settling (Appearance>Viewport colors). These reset to default colors twice everyday at sunset and sunrise. My assumption is that this has something to do with my macOS system switching from dark to light color schemes? Restarting my MacBook (M3) or Rhino doesn’t seem to have an effect either way. The only variable is whether a sunrise or sunset has occurred in the meantime. Quite frustrating having to change them back every day. Is there some way to override this or has anyone discovered the bug in the meantime? Thanks!
@Mark41 the same happens when manually switching. It’s similar to what happens on Windows when switching from light to dark mode or from custom to light or dark mode.
RH-86338 Customized colors are reset when switching to dark or light mode
Hi Gijs–Thanks for creating RH-86338. Understood that there could be a benefit to having different colors for day/night (light/dark) modes. You suggested the option of “being able to pin some colors from being overwritten”, which would absolutely do the trick in my case. Another option would be perhaps to have appearance color options for both light and dark mode so that you can customize your interface for both scenarios. As you can imagine, certain accent colors work better (higher contrast/visible) in a dark environment vs: a light environment. Also, just by the way, I’ve noticed that when these colors reset at sunset/sunrise, the rhino appearance settings window still shows my custom selection, even though the default colors are displayed in the modeling interface itself.
this happens to me too. it used to happen very occasionally in Rhino 7 / Windows 10 - maybe twice per year. Now with Rhino 8 it’s happening much more frequently, similar schedule to the original post. Thanks for the OptionsExport tip, ill use that in the interim.
I’m on Windows 11, I use dark mode 100% of the time.
Hi Nick -
Do absolutely all settings get reset or only specific ones?
Please run the Rhino SystemInfo command and copy-paste its output here.
