Latest update 9.0.26195.12303, 2026-07-14 Rhino Reset to factory
Hey guys,
Incredible work on V9 Beta — absolutely loving it! I’ve been using it as my main tool for a while now.
This morning I fired it up after the latest update, and to my surprise Rhino had been reset to its factory settings. I had to re-import all my settings and recalibrate everything to match my workflow again.
Yes, yes… I know. It’s a beta, you bozo. :grinning_face_with_smiling_eyes:
Still, it was a seriously time-consuming task during a busy morning, and I was pulling my hair out over the time I lost.
Just wanted to share my experience in case anyone else runs into the same thing.
G.
Hi G,
Good news — you may not have had to redo all that. When Rhino resets to factory (or you run Reset yourself), it doesn’t just wipe the old setup, it makes a backup of your settings first. So what you lost this morning is very likely still sitting on disk.
Have a look in:
C:\Users\<you>\AppData\Roaming\McNeel\Rhinoceros\9.0\settings
Your live settings-Scheme__Default.xml is there along with a backup copy from the reset. Close Rhino, swap the good one back in, restart.
Going forward use OptionsExport — run it any time your setup is dialed in and it writes everything to a single file. After an update or reset just OptionsImport that file and you’re back in seconds instead of an hour.
Hey @Japhy Tnx for the input.
Found this at the specified location :
And you are reffering to “settings-Scheme__Default.xml” right ? i’v grabbed a copy to my Rhino BC folder.
As for OptionsExport that’s a well known method & I’m have a updated BC at all times, did use that but there where some small & annoying things that i have to recalibrate due to that Beta update & reset issue. now that i have a copy of the setting scheme, i hope that would not be a issue anymore.
G.
Mine is empty…
and I’m left with nothing:
I can’t even dock a single panel. Frustrating.
@Piotr did your settings get wiped after installing yesterday’s beta?
Does Window → Window layouts → Default Window Layout help?
Partly. I got me to the basic which I have to start adjusting all over again, but still I can’s dock the panel. Some pink squares appear randomly over the toolbar but no docking. I can dock to the upper toolbar and right panel but not the left one.
Edit after 5 min: success after deleting the toolbars from the left panel.
you answered only the second part of my question. Did this happen after installing yesterday’s build?
Yes.
There is an ADD button on the right ribbon but not on the left one:
this is what I see when I dock 2 or more panels:
This is still not so universally working like, for example, Affinity toolbar system.
I will do the complete backup on main machine before upgrading, and I will bring these settings home. I am going to see how migrating RUI works. So far I am stuck with shortcuts from 2021 I have saved on my HD, but that’s my punishment for not being consistent enough in saving options backups.
Hi Gilad -
No. That only contains parts of the settings.
This command has been updated in Rhino 9 and does more than it did in previous versions.
Which file had your settings and what was missing when using that to restore things?
It’s not very clear to me what you mean and how that relates to Affinity
I see no add button here:
Mentioning Affinity I didn’t think about + button, but overall ease of config and stability.
Maybe it is not my day today and I’m stressed by amount of work hence my high level of annoyance - sorry for that.
Sorry for the inconvenience this caused, I have no idea how it can happen that settings get wiped. I highly recommend, once you have your correct setup back, to use Export options (this saves a .rhs file)
which can later be set back with Migrate → from RHS file
In my case OptionsImport doesn’t bring all the settings in…
Hi -
How were they exported and what is missing?
YT to track this : RH-97739 All settings wiped on newest Beta
To be picky, both the betas from 14 July and 11 August are problematic.
I’ve noted two versions specified in the ticket which are for those dates
Hi Wim,
Some of my aliases and the F-keys of the keyboard. I don’t know if also some other settings failed to load.
