Line width is still unintuitive
I never remember the “PrintDisplay” option. I always have to look it up. It’s doubly confusing because when you go into display modes, it says to use the “object’s width”. But in the properties panel of a curve, there’s no object width to change. There’s linetype scale, but it doesn’t seem to do anything. Then I get even more annoyed when I discover that all color assignments have to be re-done after enabling the option (because of course I missed that the separate “print color” is selected by default).
Also, setting the scale to 2 in the curve section of a display mode does seemingly nothing… again I’ve forgotten how to globally change curve width for a display mode because it’s unintuitive.
Is there an easy way to set the width of some curves that I missed? I don’t care about printing!
Seems V8 can’t decide if it wants to show the print colors or the object colors on close zoom as well… :expressionless:
Also, caught a bonus jump at the end there…
Linetypes have width values on them now and individual objects can have custom linetypes if you want that level of customization. If you want to adjust a width, adjust the linetype. If you don’t like this behavior, you can switch your display mode over to use fixed pixel widths which is what previous versions of Rhino did.
That is extremely unintuitive. A line type is dashed, dots, etc. It should have nothing to do with width.
Also, now that I changed the width in the type, it’s also extremely uninformative:
I never understood this and I don’t think I ever will.
I change the print width of a curve, because there’s no other width quickly accessible:
And then nothing happens in the viewport.
So, I go into the display settings to see if I can change all curves to use the print width instead of the object’s width (whatever that is) and there’s seemingly no option for it:
Why is the UX so crap around this? Why is it so difficult to change the width of a curve?
At one point, I there was a glimmer of a hope of a quick setting, but I don’t think it materialized?
