FlowAlongSrf RigidGroups In V6
Done in V7 WIP, but desperately needed in V6 for those not using the WIP
Lost the V5 ability to use groups with _FlowAlongSrf _Rigid=Yes
Use history enabled templates multiple times in the same file - shanks, prongs, 3D printing supports.
Allow History To Work With Ref Objects
Opens the door to a lot of history enabled workflows/templates.
RigidGroups doesn’t work like the V5 workaround (wrap in a _Block before flowing).
CurveThroughPolyline MergeCrv Option
Let _MergeCrv be a sub option in _CurveThroughPolyline to reduce clutter with symmetrical patterns.
A few small issues with _BlendSrf.
PreserveStructure Creates Periodic Srfs
Do a TSplines V3 like _FlowAlongSrf.
SelColor - SelPrev Cleared, Default Behavior
Matrix style one click to select layer.
Gumball Align To View (_DragMode _View)
Align gumball to view (TSplines gumball)
Done in V7 WIP
Rebuild: Supports History when Delete Input is unchecked
Let’s you rebuild a _FlowAlongSrf target without breaking history.
Done in V7 WIP
Add Normal Control to _Flow
This will give us history enabled stone layouts, which we can’t do with _FlowAlongSrf (no control over physical stone spacing and UV orientation) or _Flow (no control over normal orientation).
Requests I am still working on:
- Arrays with Scaling Controls - Working on a general use funtion that lets us do tappered stone layouts with history.
- Blocks - Long list of QoL improvements for working with blocks and history.
